Results 1 to 10 of 10
Thread: When to apply Pebble Sheen in wet weather? Ground Hog Day!
    Jun 2016
    The Woodlands, Texas
    2
    Hello,
    We are putting a new inground pool in our backyard. Being near Houston in The Woodlands we have had torrential rain for it seems like weeks on end. This is the last step for us since the gunnite has be sprayed for a couple of months now. Every time it rains the pool fills to a couple of feet and when my builder drains it there is seepage or weeping of ground water back in. He is getting a little frustrated as we are! And there are some rust stains and leakage around some of the penetrations. The gunnite was applied with drains to let the ground water in during curing to relieve pressure. PebbleTec is being cautious too since they don't want to do a crummy job. Anyone out there experiencing this kind of delay? Just be patient right? Can't wait to dive in when it is all finished!
    Stan
    20000 gallons
    Jandy pumps
    DE filter
    Swimming jets
    Paramount floor clean system
    IrwinK's Avatar
    Apr 2016
    Orlando, FL
    338
    Re: When to apply Pebble Sheen in wet weather? Ground Hog Day!
    Same situation here in Florida. Mine has been sitting with about a foot of green water now about 2' for almost 3 months since the gunite was sprayed. At first they pumped it out a few times but now they don't bother. PB says water won't hurt it but the gunite in deep areas has never been dry.
    I expect plastering in about 2 weeks as they won't do before my screen enclosure is installed.
    My 2016 Build 14'x19'x35' IG Gunite 15K Gal. Roman, 4'-5' deep, 6 returns, 3 sheers
    4 deck jets, 2 Pentair XF22005 Pumps, Clean&Clear 200 Cartridge Filter, Brick Coping
    2 Pentair 5g 12v LED Pool Lights, 1 Pentair 12v Globrite LED in step area, 2 Bubblers
    Inline Chlorinator - SWG later, WetEdge Mediterranean Pebble, Intermatic MultiWave
    43'x33' Screened Paver Deck&15'x30' Lanai, Doheny Discovery (S200) Robot, TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Definitely be patient. It seems like eternity but even this year with the freaky weather it will eventually get hot and sunny again. Even if you had to wait a month, which would be horrifying I know, it is better than 20+ years of issues from a poor application. Or a chip out and redo later.
    So, the answer to your question is you apply Pebblesheen when the pros say it is time.
    Aug 2014
    Houston tx
    2,524
    Oh, and Welcome to TFP Stan! Don't forget to post pics of your build. We love pics! You will find lots of people willing to help answer any questions you may have as the build progresses ( or in your case-doesn't. )
    If you haven't gotten a test kit yet, get the TF-100 and splurge on the SpeedStir. It's a great tool! You can find it at TFTestkits.net
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    DFW, TX
    24,450
    Hey, that was your first post. Welcome to TFP!
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,215
    Hi Stan! I live in Cypress (vicinity of 249 and Spring Cypress) , so I know about the rains! Ugh! My pool had gunite for a long time, too, before plaster - in part due to all the rains we had last spring and June. As pooldv said, just be patient. The PebbleTec group of MMG did mine (I'm assuming you will have the same company) and was outstanding! They were probably the most skilled of all the different crews I had. I missed out on getting MMG for the gunite.
    I was very worried about the rust stains and other stains, but I didn't need to be. PebbleTec sent out a guy the day before to do a final check of the pool and take measurements. He took lots of notes. He said we could power wash the stained areas before the pre-clean up crew that was coming the next day. He said not to spend a lot of time, because the pre-clean up crew would also power wash. He said it would be helpful, so my son did what he could. The pre-clean up crew did a great job. The plaster guys (came 1 or 2 days later) were phenomenal! You're in good hands! I also vote for pictures!
    Take care!
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    Jun 2016
    2
    Thanks to all respondants! If I did it right you can see a picture I uploaded. It is going to be a great pool but now an ugly duckling.
    Patience is a virtue I don't have. Oh well, plenty of other things to do like build the shower, add a tiny water heater I found online, build the pool equipment enclosure, and the list goes on. One good thing though, you get too hot working and you can jump in the pool (maybe if it ever gets finished). Wife MC and I felt that since we are both nearly retired and have married kids with no grandchildren, if we build it they will come! Looking forward to the pool life. Will definitely buy that chem kit. It has
    the test for cy acid right? Thanks for the WARM WET welcome to TFP forum. We look forward to fun and solving problems as they come up.
    Aug 2014
    Houston tx
    2,524
    Yes it definitely has the CYA testing reagent. Looking forward to seeing more of your build!
    Oh and if you become a supporting member of TFP, you get a discount on the TF-100 test kit!
    Marla
    Apr 2015
    Houston, Texas
    3,215
    Quote Originally Posted by stanrusek View Post
    I had to chuckle when I read this. I'm retired and found it was getting more difficult to work in the garden with the sweltering heat. Now it's my favorite thing to do! In fact, sometimes I just jump in with my yard clothes on then go back to pulling weeds or whatever!!
    I wondered the same thing about 'build it and they will come'. It works! My son in college in Oregon may not be able to get here often, but now he can't wait to be back in the pool. And I've found he stays much longer - which I love (most days - )
    DFW, TX
    24,450
    Just don't feed them too or they'll never leave!
    +1 to hopping in the pool multiple times a day while working outside. Makes the heat easy to take.
