I married into my pool and my husband has never been the one to deal with it so he's not a big help other than physical labor.
I have an in ground pool and this is my first. My issue is that I have a leak in my pool step gasket.
My story, The pool was not used or covered for 5 + years. I did a drain and clean and it is sparkling. . When I filled to the steps it started leaking. It is the entire step area that will not hold water . Everything below that holds perfectly. I have had someone give an estimate on replacing the liner ($2300) and steps ($3000) but I think it is just the gasket.
I need to know if anyone has replaced a step gasket... Is there any videos or pics with step gaskets being replaced? Where do I start in this process. Would much rather replace the ($10) gasket than the entire liner.
