Results 1 to 15 of 15
Thread: My pool turned Green!
    paulmaz's Avatar
    Apr 2016
    San Antonio, TX
    114
    Angry My pool turned Green!
    Hi again pool pros,
    I have reported on here over the last week that we had a storm, and that my pool filled up and I had run in. Was contemplating a SLAM to clear it up, but held back, and maintained an elevated FC (~11-13, with my CYA of 60) Have been scrubbing and vacuumed a handful of times. Last few days pool has cleared up some, but still needed some time....was feeling good!
    Then yesterday not long before heading home from work I get a call from the wife saying the pool is green! I said no its not, just cloudy a bit! Well sure enough when I get home, it is green. Pretty clear, but green! Now this drive me nuts, because I can promise my FC was never below 10! So with this, I calculated I needed 3 gallons to get to SLAM level, so I put that in last evening to start my SLAM. Before the SLAM, these were my numbers:
    FC 11
    CC 0
    pH 7.4
    CH 400
    CYA 60 (maybe 65)
    Did not run Alk test.
    So I guess my question is...what gives? Is algae able to start even with a good FC level? I am only a pool owner of a few months and brand new to TFP, so this bugs me, and confused! I think I am going to run up to Leslies and see what they can do for me! they have the answers right?? (jk on Leslies part....)
    Anyway, thanks for any guidance in advance!
    -Paul
    15k gallon IG plaster, 26x39 at widest points, sort of shaped like the great state of Texas!
    B2854 Pentair Challenger 1.5 HP single speed motor
    Tagelus TA-60 Sand Filter, Polaris 280, TF-100
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: My pool turned Green!
    Clear and green usually means metals. Pool School - Metals in the Water and Metal Stains
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Be sure to have Leslie's test for metals. Green, but clear water is usually a metals result. I would post results and get recommendations before buying all the pool store recommended products. Sorry for your struggles.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    paulmaz's Avatar
    Apr 2016
    San Antonio, TX
    114
    Metals? Seriously? How did I get metals in my pool? It's not that 100% clear...still cloudy a bit.
    Were you guys serious about having Leslie's test for metals? I was kidding about running up to Leslies.
    -Paul
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Are you on a well? Ever use algaecide?
    Can you take a picture for us?
    paulmaz's Avatar
    Apr 2016
    San Antonio, TX
    114
    Quote Originally Posted by Mr Bruce View Post
    Not on a well, but did add water earlier in the week. Here in San Antonio our water comes from an aquifer. We do have hard water. For house, we have a water softener. I have never used algaecide. Will have wife send me a few pics to post here in a bit.
    -Paul
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    If you cannot pass an OCLT, you should SLAM. Not half hearted elevated FC levels, full on SLAM with ladders out, lights out, lots of brushing and several test/adds per day.
    paulmaz's Avatar
    Apr 2016
    San Antonio, TX
    114
    I started my SLAM last night. I put in 3 jugs of 10% around 6pm, tested FC around 10pm and was 33 (BTW, I don't think I have a 25k gallon pool, because I was expecting an FC of 25!) I checked my FC this AM, and it was 27. Heading home at lunch to test again. will add 10% to maintain FC around ~30.
    Wife is sending pics now. will post in a few.
    -Paul
    paulmaz's Avatar
    Apr 2016
    San Antonio, TX
    114
    My wife sent these....still cloudy a bit. you can see the green. Really hope this is not metals. Hoping a good ole SLAM will clean this up!
    -Paul
    paulmaz's Avatar
    Apr 2016
    San Antonio, TX
    114
    Looking at pics, water really is not clear. So is this just algae? hoping not metals. If it is algae, my original question still holds...you can have an outbreak even with recommended FC levels?
    -Paul
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Yeah, that's not the classic metals pool, your pool just needs a good old fashioned SLAM
    Pool Tool's Avatar
    May 2014
    757
    "If it is algae, my original question still holds...you can have an outbreak even with recommended FC levels?" Short answer is No - there was a point in time that FC dropped too low. Maybe it was an area with poor circulation and warmer temps allowed it. Once algae establishes it can multiply faster than the lower FC levels can eradicate. A SLAM should remedy it pretty quickly.
    Btw, I recently visited SA for the first time - very nice city. And gorgeous pool!
    paulmaz's Avatar
    Apr 2016
    San Antonio, TX
    114
    Thanks guys for the quick responses. Will keep you posted on results of SLAM.
    BTW, my in-laws are all from Wisconsin, and HUGE Packer fans. My father in law is from Racine and my mother in law from Tomah. I love Wisconsin! Although I see you are in Chicago, but assuming you are from WI...
    -Paul
    paulmaz's Avatar
    Apr 2016
    San Antonio, TX
    114
    Went home at lunch and my FC was 24.5 so 2.5 loss from 7am. added 10% to get to FC 30. Also scrubbed it, and green dust came up. Will vacuum tonight, measure and adjust. Man this snuck up on me fast. I guess I had a lapse in there. Live and learn.
    -Paul
    Pool Tool's Avatar
    May 2014
    757
    Your inlaw's sound like good people!
    It does happen fast, but you will find in time that you will notice things with your pool sooner and will become proactive vs. reactive. Kind of like hindsight always being perfect, experience is that stuff you learn right after you need it!
