Thread: How often to lubricate o ring seal?
    Feb 2016
    CYPRUS
    56
    How often do you apply lube on the basket filter o ring?
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,799
    Re: How often to lubricate o ring seal?
    It only needs a very light coating all the way around the oring. By the book its every time you take it apart, in reality you only need to add more when there isn't enough squished to the side to grab with your clean finger and relubricate the center.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Jul 2015
    Central Valley CA
    1,108
    I have done mine once in the 6 or so times I have removed it since the pool was built in October. Hair nets in the skimmer make having to get into the pump basket a rare event.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Feb 2016
    CYPRUS
    56
    Thank you both, much appreciated.
