Results 1 to 13 of 13
Thread: After a few hours of the pump keeps running, but the water stop circulating!?
    Aug 2014
    westfield
    60
    Have a 15 x 30 above ground pool to horsepower two speed water pump and sand filter. Hadn't noticed it before because I thought it was the timer going off during the time I get home from work. Yesterday I noticed that after about three hours of the pumping on, the pump continues to run but the water stop circulating! If I flip the switch and turn the pump off and then back on, the water start circulating again.
    Any idea why this would be happening and how to fix it?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: After a few hours of the pump keeps running, but the water stop circulating!?
    Add your pool info to your sig so that we can better help you. Here's how, Pool School - Read This Before You Post
    It wouldn't hurt to add your state to your location in your profile too. Climate is often an important factor when we help you with your pool.
    May 2016
    Amarillo, Texas
    38
    Your pump curve will have a dead-head pressure where the flow will drop to zero at that pump head. So too much head to pump against (dirty filter) will do it. Also, a clogged impeller can significantly change your pump curve so it doesn't take much pressure to get there. Especially at low speed.
    I would at least start with checking the impeller to eliminate that cause.
    Aug 2014
    westfield
    60
    an abobe ground pool, 15 x 30 with side deck. Live in western MA. Opened it ( or at least started) Friday June 3rd. I also posted this info as part of another post, which now I think is related! Aquabug not cleaning whole pool
    Connections are with 1.5in flex pvp pipe/hose.
    Aug 2014
    westfield
    60
    Here's a picture of the pump+ filter I took when I was opening the pool.
    May 2016
    Amarillo, Texas
    38
    In your other post, you had algae. Are you regularly back washing your filter as it could be clogging in 3 hours. Are you sure the pressure gauge is working if you are using that to determine backwash?
    Aug 2014
    westfield
    60
    Quote Originally Posted by Pchase View Post
    sure, no. It seems to be as it goes to zero with pump off and goes up a few lb over a few weeks (last year, this year hasn't even been a week yet. Let me know if there is something else I should be looking for. Thx
    Isaac-1's Avatar
    SW Louisiana
    6,711
    How does the pool look? If the water is clear you may need to deep clean your sand filter Deep Cleaning a Sand Filter
    May 2016
    Amarillo, Texas
    38
    Quote Originally Posted by askinstuff View Post
    I had an extremely low flow problem myself recently so I pulled off the motor and checked the impeller. It was clogged with grass. That can fit through the skimmer baskets and pump baskets. I pulled it out, slid the motor back on and everything ran great after that.
    Aug 2014
    westfield
    60
    After reading a bunch of posts, I'm wondering if I have an air leak or the impeller has debris! From what I've read, 6 psi seems awfully low. I'm going to look and the impeller hopefully later today. Anything else I should look at? How would I check for other air leaks?
    Aug 2014
    westfield
    60
    I'm an idiot! The PSI that I referred to above was when the pump was on low. When it's at high-speed it to 12 to 13 PSI, which seems more normal.The water is now more cloudy than green. Seems like the pump stayed on overnight on low. I back washed it for about 5 min last night. So maybe that was it. Fingers crossed!
    Aug 2014
    westfield
    60
    Here's how it looks now (through. Window screen)
    May 2016
    Amarillo, Texas
    38
    So you were definately deadheading your pump on low speed. Here is a link on some Hayward pumps and all of them only have a capability of pumping 13-17 feet, even at zero flow. That's about 5.6 to 7.4 psi, so you were right at the capability of the pump.
    http://www.hayward-pool.com/pdf/lite...loIISS2011.pdf
