Results 1 to 8 of 8
Thread: Eco
    Aug 2014
    Olathe, KS
    25
    Eco
    My pumps about 12 years old. Yep it's been around for a while. It's a 2hp pentair, not sure of the exact model. A couple of days ago it's started shutting off and turning back on by itself. It's overheating. I tried the easy fixes, but I'm thinking it's probably time replace the whole thing or at the least, replace the motor.
    From what I've read a 22000 pool , with 1.5 pipes, and a estimated 70 ft of head pressure most of the 1.5 hp motors would make a good replacements. The sand filter is huge so I'm thinking I could go bigger, but with the smaller pipes it's probably a waste.
    Has anyone found a pump that stand out above the rest? I was looking on Amazon and it seems like the most popular ones right now are the single speed pumps, which is what I have now. I was hoping there was a general consensus on the best overall value. Are the two speed and variable speed pumps worth the extra cash?
    The EcoPumps are variable speed and have a three year warranty, but are they any better than Hayward or Pentair?
    I'm just looking for suggestions I guess.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Eco
    Yes, a 2 speed,or VS pump will save a lot of electricity over a single speed pump.
    I am a fan or the Pentair Superflo, either VS or 2 speed. Both are available in 1-1/2hp.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,822
    Re: Eco
    I love my super flo pump its very quiet. You can't hear it unless you are standing right next to it. You may want to consider an inteliflo pump tho they are a lil more expensive but you may get better performance and better electrical savings over the super flo.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Aug 2014
    Olathe, KS
    25
    Re: Eco
    Sounds like you're both happy with the Pentair's .
    Mar 2016
    El Dorado Hills, CA
    14
    Re: Eco
    I too was looking at the Ecopumps a little while back, but as some chimed on my thread, fairly new company, their ads, and website uses fancy words for some of the same stuff in every pump to make theirs sounds better. It's a newer company, not as long of a trackrecord, etc etc.
    I ended up going with the Pentair VS 3hp pump model # 011018.
    Hope this helps
    Aug 2014
    Olathe, KS
    25
    Re: Eco
    I was looking at that same model and have been going back and forth between it and the Superflo VS. Today I called a couple of places. My usual place had the best price but only has the the Intelliflo 2. They are asking $1500 for it, installed, or $1150 for the Superflo VS. i'm going to bite the bullet and get the intelliflo.
    Pentair's warranty make's it pretty risky to install it yourself, which kinda sucks, but I can see why they do it.
    DFW, TX
    24,502
    Re: Eco
    It's a great pump, you'll definitely be happy with it.
    Aug 2014
    Olathe, KS
    25
    Re: Eco
    I ended up buying te Superflo VS and installing myself. So far so good. Onto the next project. Lighting.
