Thread: Pool vacuum??
    Baeritto's Avatar
    Jun 2016
    Arlington, TX
    83
    Pool vacuum??
    I am awaiting my test kit. It should be here tomorrow. Is a pool vacuum necessary and if so, what do you guys recommend? IG plaster.
    (Salt water pool, **estimated until further notice**12,000 gallons, currently a SWAMP, 3-5 foot deep, DE filter, *i don't think I have a SWG?)
    SWG IG pool, *estimated until further notice* 12k gallons, DE Filter, in ground skimmer, currently a SWAMP.
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Re: Pool vacuum??
    You have options on how to clean schmutz out of the bottom of the pool.
    Your choices include a fancy electric robot ($$-$$$), a small battery vac ($) or manually (less than $!) by using the skimmer, the long vacuum hose and a pole.
    How to vacuum an Inground Pool Video - YouTube
    Take a pic of your equipment pad and we can tell you if you have a SWG.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,237
    Re: Pool vacuum??
    I'm with Yippee - minimum is a telescopic pole, leaf scoop attachment, brush attachment, vacuum head attachment, a hose in good shape, skimmer plate, and if needed, a cuff for attaching the hose to the skimmer plate. If there's a vacuum port on the pool, I wouldn't use it until after the pool is clean. I'd think about automated cleaners after ending the mystery of what's down there, assuming you don't know the history of the pool.
    I have a 12K pool, and I swear if I had a main drain, I could do it all with a leaf scoop and the brush. That said, for a swamp, I would close the main drain valve and not play with it until after I could see the intakes at the bottom of the pool.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
