Thread: Need Help - Unibead Liner
    cubbienate's Avatar
    May 2016
    Hampshire, IL
    87
    Hello all!
    Great day today the pool is up and filling. Our liner has a few wrinkles in the bottom right now. Do we need to smooth all of those out or will it spread as the pool fills? We are at 510 gallons right now so I wanted to check before we fill all night. Thank you in advance!!
    15'x24'x52" Saltwater 5000 Oval AGP, Hayward S180 Sand Filter / 1.5 HP Power Flo Pump, Hayward AquaTrol Chlorinator, TF-100 + Taylor K-1766
    Re: Need Help - Unibead Liner
    Not sure if this is the same situation as you would find yourself in with an Intex, but if it is, you should definitely get the creases out when there are only a few inches of water in the pool.
    cubbienate's Avatar
    May 2016
    Hampshire, IL
    87
    Quote Originally Posted by Gabesdaddee View Post
    That's kinda was I was thinking.... I stopped filling for the night it was a bit too cold to screw around out there tonight. Back at it tomorrow I guess. Thanks for the reply!
    Casey's Avatar
    SW PA
    10,448
    The creases will not smooth on their own. You need to pull the wrinkles out or they will stay there. It's not a terrible problem but they can be unsightly and collect dirt.
    cubbienate's Avatar
    May 2016
    Hampshire, IL
    87
    I am glad I stopped filling! It seemed like it wasn't getting better and after we put the track on we got the wrinkles. Back at it tomorrow! Thanks for the reply!
    Casey's Avatar
    SW PA
    10,448
    Don't add anymore water til you get them out. Need anything else, just ask.
