Thread: Should ammonia be zero?
    Jun 2015
    Northampton PA
    26
    Apologies if this is in the wrong section.
    Should ammonia readings be zero? My reading is less than .25. I have goldfish aquariums, so I have ammonia tests. BTW, don't use the test strips from the pet store. They are as bad as the test strips from the pool store. Use the drop test.
    Pool Size: 5,000 Gallons Above Ground
    Cartridge filter
    Proline Clear water element filter
    City water, no restrictions.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: Should ammonia be zero?
    Yes, ammonia should be 0. Increase FC to clear it.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    In a perfect world, yes.
    But sweat and urine contain urea, which can form ammonia. So anytime you have swimmers in the pool, you're likely goingto have some before the chlorine can neutralize it.
