Thread: Run Pump 24/7 or let it rest?
    Susiejax's Avatar
    May 2016
    Fort Wayne, Indiana
    50
    Hi --
    Just wondering what you all recommend as far as how much you run your pumps. When the pool chemistry is healthy, do you turn it off any?
    Thanks
    22,400 gal; in-ground gunite rectangle, vinyl liner; 3.5'-8' depth; Chlorine; auto cover; Hayward Pump and Sand Filter; Hayward Electric Heatpro; diving board; 3 sidewall fountains; open mid May thru mid October; built 2011; Taylor K-2006C FAS-DPD Test Kit
    Jun 2014
    15,186
    Re: Run Pump 24/7 or let it rest?
    In most cases it is not necessary to run the pump 24/7. Only long enough to mix chemicals, vacuum, and pull debris from the surface into the skimmer. You can learn more on the TFP Pool School - Determine Pump Run Time page.
    Jul 2015
    Central Valley CA
    1,109
    Short answer is you can probably get away with 4 to 5 hours a day long answer is depends on the pool and the owner. If 10 people reply you will probably get 8 different answers.
    Take a look at THIS
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Susiejax's Avatar
    May 2016
    Fort Wayne, Indiana
    50
    Thanks! Not sure how I missed that part of Pool School....
    Jun 2014
    15,186
    TFP overload. It happens to all of us. Smoke starts coming out of our ears sometimes.
