Results 1 to 10 of 10
Thread: Aquapure RS under reports salinity
    Apr 2014
    North Carolina
    5
    My Aquapure 1400 SWG is under reporting salinity by 500-800ppm when compared to Pool Store testings. Bad Flow sensor? Bad SWG? Bad board? Bad pool stores? No errors on board. Flow lite ok. Any thoughts would be greatly appreciated. Thanks.
    DJ
    15K Inground Gunite
    Jandy (Zodiac) Aqualink System
    Aquapure 1400 SWG
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Re: Aquapure RS under reports salinity
    Welcome to TFP!!
    Is it
    1. - Producing chlorine and just under reporting salt, or
    2. - Is it not producing chlorine because it thinks salt is too low.
    Oh, the pool store testing being faulty is another possibility that you have already identified.
    Support the site
    Get the Taylor k-1766 salt test kit. You can calibrate the Aquapure if necessary.
    Support the site
    Jul 2012
    Southeastern IL
    21
    It's as likely the pool store reading is off as it is your SWG is under reporting the level. Salt readings are inaccurate, as long as your SWG is within its recommended salt range and is working I wouldn't worry about it. I have seen mine differ by more than 1000 as compared to strips and it continues to work fine year after year.
    18x36 IG Vinyl, ~25K, TF-100, Jandy 1HP 2 Speed Pump, Jandy AquaPure 1400 SWG,
    Hayward DE 3600 Filter, Pentair MasterTemp 200 NG Heater, DIY Install in 1990
    May 2015
    Union, NJ
    128
    Quote Originally Posted by robhdrider View Post
    I agree with JamesW. Get the salinity test and take from there. My SWG have been over reading since last year. My pool still under warranty and so far 3 sensors have been replaced, the board was replace yesterday and still having incorrect reading, which at times make the SWG stop producing chlorine. I normally test using the aquacheck salt strip and take my water to two different pool store just to confirm make test is accurate.
    20,000 Gallons, 33.9 x 19.9 free form inground plaster pool 7 feet deep with Spillover Spa, Salt Generator (Fusion Soft),Heat Pump, Single Speed 2 HP Pump, D.E. Filter. Zodicac PDA, IQ900RS Controller.
    Jun 2011
    Long Beach, CA
    2,790
    How old is the cell?
    Apr 2014
    North Carolina
    5
    WOW! Really quick responses to my SWG problem. Thanks to all!!!! My SWG is producing chlorine ok. However, I'm afraid that when the salt level is too low. it will report it on my PDA "add salt" and I'll have to figure out how to clear the message. The cell is about 3 yrs old. No error codes,flow light is on, SWG producing chlorine.Everything looks good except the salinity. My reading is 3000ppm. One store has 3500ppm and another has it 3800 ppm. Descaled the cell today-same reading 3000ppm. (i've always kept my salt level at 3200ppm). To JamesW--- I'll get the Taylor K 1766 test kit, but how do you recalibrate the cell??
    Again, thanks to all! It's appreciated!
    DJ
    15K Inground Gunite
    Aquapure 1400 SWG
    Here is the recalibration procedure.
    • Press the “Salinity” button and hold it until it beeps 3 times.
    The system will beep when you push it and then at 5 seconds and again at 10 seconds.
    Release the button after the 3rd beep.
    • Press and release the “Temperature “ button within 5 seconds to enter the salinity calibration screen.
    • The system will display the salinity reading, press the up arrow
    to increase the reading and the down arrow to decrease the reading.
    • When the proper reading is reached press the “Temperature” button within 5 seconds to store it in memory.
    Support the site
    Apr 2014
    North Carolina
    5
    thanks JamesW
    DJ
    15K Inground Gunite
    Aquapure 1400 SWG
    Jun 2011
    Long Beach, CA
    2,790
    My Aquapure was always a few hundred points below the K-1766 reading. My AquaRite has been within 200 points at all times except when the first cell died.
