Thread: DE sediment in pool
    Jun 2016
    Massachusetts
    10
    DE sediment in pool
    Just bought a house with a DE filter. The filter was in the basement for the winter and didn't look like it was in bad shape. I noticed a couple of spots where the fins had been repaired with some epoxy but it doesn't appear it is filtering much out of the pool. The PSI hasn't changed more than 1 or 2 and when I add DE after back washing it pours through the return jets into the pool. Can small holes cause this large of an issue? I figured it would work at 90-95% capacity if less than 1% of the filter surface area had rips. Are there any cheap repairs? It looks like replacing all the fins could be 500-700 bucks. All my levels are good except a lot of powdery sediment on the bottom (DE, dead algae, pollen, hopefully not gunite!)
    Thanks for any advice.
    40x20 Inground gunite pool, Nautilus NS72 DE filter, Hayward super pump
    38,305
    Re: DE sediment in pool
    Welcome to TFP!!!
    You should be able to get a full set of grids on Ebay for ~$150. That is where I got my Unicel grids.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Welcome!
    You need new grids, period.
    What you were trying is akin to hoping a balloon will hold air because it's just a pinhole.
