Results 1 to 8 of 8
Thread: Another Liquidator thread...HELP guild me! :)
    May 2014
    Nevada, TX
    238
    Hey everyone! well, its swim time again, and I am DESPERATE to add some automated help to keeping my FC up this summer!
    I looked at the The Liquidator last summer, and I have seen people who have had great success with it, and others who had nothing but disappointment. I have also seen the other pump systems but like many others, I cant really afford the extra expenses RIGHT NOW...and I need a RIGHT NOW solution. I do have a 27' round...at 54" and I have seen some say that there may be a "Large pool" corolation with issues associated with the liquidator. I am looking for some current feedback and success (and failure) and things that may help over come some known issues that I can consider.
    Much appreciate any and all input!
    Thank you,
    Steve
    27'x54" Sharkline Venture
    Hayward X-Stream Full-Flo 150 sq. ft. Cartridge Filter
    Matrix 1.5HP Dual Speed Pump
    Hayward Aqua Critter Automatic Above Ground Swimming Pool Vacuum Cleaner AR500Y
    TF-100 test kit
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Re: Another Liquidator thread...HELP guild me! :)
    I have been running a LQ for 2-3 months. I love mine, but YMMV. Here is my advice, in no particular order
    If you don't have room for it on a concrete pad (I did not), get a 16" x 16" paver from Home Depot to put it on (approx $4). Get a level and add dirt to make sure your paver is level, too.
    When you install it, as you tighten the hose clamps, the friction will pull the pressure fittings out of flat with your PVC. Be sure to keep them straight as you tighten the clamps. Expect a few tries to get a no leak install, but easily do-able, even while enjoying a tasty beverage.
    Pay attention to the orientation of the inlet and outlet hoses. Theoretically, you want the shortest hose runs possible, although this is not really critical.
    Make sure you get the model with 3/8" fittings. This IS critical.
    Pay attention to the opening of the lid. You want this to be convenient. Do not install such that you have to hold the lid open while you pour.
    Get the throttle valve (about $12) from US Plastics. It is precise enough. The adjustable valve which comes with the LQ is all but useless for dosing, but is PERFECT for an ON/OFF valve.
    You will need that ON/OFF valve for sure, until you get the system dialed in.
    Add 50 ppm borates. Get the GRANULATED Boric acid from Duda Diesel. No need to add MA that way, and the boric acid is easy to throw in the pool. If you don't do this, you may get the white flakes (I do not get them).
    If possible, keep the tank out of direct sunlight (I could not) to reduce chlorine degradation. Not that critical, since we are adding maybe 2-4 gallons a week.
    Wear old clothes when you add the bleach. Just because.
    Add bleach through the attached black funnel only. Better if your pump is running as you do this, since you can add more bleach more quickly.
    Make sure everyone can see the "Liquidator" label on the tank if possible. Its just cool
    FYI: My pool maintenance time has decreased by 3/4 since adding the LQ.
    30,000 gal free-form IG w/ spa, PebbleSheen Blue Surf, Pentair cartridge filter, Pentair 3 HP Intelliflo, extra pump that is way over-sized for weeping moss rocks, Dolphin Oasis Z5, municipal water, all built Jan-Feb 2016. TF-100, SpeedStir, Liquidator 3/8", borates. My build thread http://www.troublefreepool.com/threa...-in-Cypress-TX
    May 2014
    Nevada, TX
    238
    Quote Originally Posted by MarkTX View Post
    I have been running a LQ for 2-3 months. I love mine, but YMMV. Here is my advice, in no particular order...
    ...Make sure everyone can see the "Liquidator" label on the tank if possible. Its just cool
    ENCOURAGING!!!
    Love hearing this! thank you for responding!
    Steve
    TF-100 test kit
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Just measured, 14 x 14 is big enough footprint, my paver is 15 x 15 just because I liked that one
    May 2014
    Nevada, TX
    238
    I
    Hey Mark, can you help me out here? I am looking for this throttle valve at US Plastics, and it's not pulling anything up using that search criteria. Would you happen to have a link to the one you purchased?
    I just pulled the trigger and purchased the Liquidator! should be here in about a week!
    I see a lot of people using a needle valve....those seem really expensive (like 70+ just for the valve)
    Much appreciate the help!
    Steve
    TF-100 test kit
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    This is it, thanks to recommendations from other TFP members,
    http://www.usplastic.com/catalog/ite...9061&catid=662
    I guess throttle valve was not the right name. But this is the right part, and what I have, according to my invoice.
    May 2014
    Nevada, TX
    238
    Thank you so much Mark!
    TF-100 test kit
    May 2014
    Nevada, TX
    238
    Just snagged 2 of those valves! just figured might as well keep an extra on hand just in case!
    TF-100 test kit
