Thread: Hard Plumb help
    May 2016
    Maysville/ky
    13
    Hard Plumb help
    Hello again, Looking for some advise on hard plumbing our agp. Thanks to this forum Pool water is the best it has been in the 3 years we have owned the pool. Every time i get in i just marvel at how clear it is! Now I purchased and installed a new hayward de filter and would like to hard plumb it. Would anyone want to take a stab at telling me what exactly i will need? I have looked at others projects on this forum but not sure if I need anything special. Because the new filter doesn't have a backwash I would like to install a splitter. I believe I will need to take it off the plastic stand that the pump and filter currently sit on. Does this project require draining the pool below the return line? Thanks for help in advance!
    IMG_20160607_202753.jpgIMG_20160607_202741.jpgIMG_20160607_202739.jpgIMG_20160607_202735.jpgIMG_20160607_202747.jpg
    24' AGP Hayward DE CE50
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,750
    Re: Hard Plumb help
    Not sure what you mean by splitter. But it looks pretty strait foward you have threaded fittings in all you pictures so you can just get threaded adapters for pvc and plumb your heart out. If you can get a plug in the return line long enough to thread in a ball valve there you should be all set.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    May 2016
    Maysville/ky
    13
    Re: Hard Plumb help
    Thank you.
