Results 1 to 10 of 10
Thread: Am It Really This Easy? Or Just Luck - Water is Perfect with Chlorine ONLY!
    Apr 2016
    Casa Grande, AZ
    66
    Hi,
    Didn't know whether to post this in the AGP or the Chemistry part so...
    But - does the TFP method REALLY make things THIS easy?
    A month into it now and chemical wise once I got the stabilizer in (CYA is steady at about 45 now and I haven't added any more so far) - the ONLY thing I have had to add to date is chlorine in varying amounts - NO Borax, NO Baking Soda - and my tests are GREAT every day - PH is exactly 7.5, and all the weekly tests are right in line - and THIS is how good my water looks this afternoon.
    Attachment 49732
    Now, I did have the dust/sand issue I posted about - but once I got the new pump and cleaner - 99% gone!
    I am not spending more than 3 minutes a day testing the chlorine/PH and adding bleach.
    COST - less than .30 a day in bleach.
    THANKS!!!!!
    Intex 18'x9'x52 - 2800 GPH Sand Filter/Pump - TF100 Test Kit
    38,300
    Re: Am It Really This Easy? Or Just Luck - Water is Perfect with Chlorine ONLY!
    Yup, it is that easy ... and inexpensive
    Consider Becoming a TFP Supporter with some of that saved money so we can keep helping others
    For that matter, stick around yourself and help others
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Would you say you have a.... Troublefree Pool?
    Apr 2016
    Casa Grande, AZ
    66
    Thanks - I will do what I can. On a slightly serious question though - should I expect to EVER need the Borax or Baking Soda? What would cause things to get out of balance where I would. I can imagine that at some point I will need to add CYA since I am leaving the pool up full time - but I have no idea what might generate the other items.
    Richard320's Avatar
    Jan 2010
    19,009
    Quote Originally Posted by sh9730 View Post
    I've never had to add either of those. I get more than enough in my fill water and I'm sure you do, too.
    Perhaps a mishap while adding acid could cause you to need those items, but that's about it. You'll never need to buy Calcium, either.
    Apr 2016
    Casa Grande, AZ
    66
    Well that was a wast of 20 bucks sitting in the garage! Thanks.
    Richard320's Avatar
    Jan 2010
    19,009
    Borax is good in the laundry. Takes the stink out of sweaty socks. Making Soda is useful for all kinds of things. Better than twenty bucks' worth of pool store snake oils.
    Casey's Avatar
    SW PA
    10,446
    You can use the borax n baking soda to wash clothes.
    Enjoy the simplicity of your pool!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    if you're talking about CH up, you can use it to melt ice on your driveway! (yeah, i know your in AZ!). haha
    welcome to easy street!
    Divin Dave,
    May 2012
    Montville NJ
    545
    Rarely - very rarely - I will have to adjust my pool after a very long rain. Other than that, it basilally runs on autopilot - about a 32 oz of %8.25 per day. maybe a little more or less depending on usage, but thats about it. Unless of course I feel like upping the boartes, and then its some borax and dry acid to even it out. Slowly but surely the borate levels in my pool are rising.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
