Page 1 of 5 1234 ... LastLast
Results 1 to 20 of 82
Thread: Noob looking for advice
    May 2016
    Bristol,CT
    34
    Hello! My name is Jim and I have a new to me 25k inground pool. See signature for details.
    I went crazy with chemicals after I pulled the cover off to discover a green mess. I threw Algaecide and Shock from the local box store. Got the green gone and then flocked it to get it to settle . I have been vacuuming, scrubbing the walls, and rinsing the cartridges in the filter. Filter has been running a week and it is still cloudy. I got the PH and TA good 7.8/130 before I bought the Taylor K-2006 testing kit.
    Here is what testing tonight. First post here... so go easy on me!
    PH 7.6
    FC 0.8
    CC 4.2
    TA 130
    CYA 0 (never got the dot to disappear)
    CH (never got the solution to turn red. It was purple-ish blue)
    Looks like I need a boatload of chlorine. Any advise would be appreciated as it would get my kids off my back!
    Thanks!
    25K Gal IG Vinyl Built 2006 | STA-RITE System 3 Cartridge Filter S7M120 300 sqft | Taylor K-2006 | City Water
    38,271
    Re: Noob looking for advice
    Welcome to TFP!!
    What was the "shock" that you added?
    With the 0 CYA and the high CC levels, you could be a candidate for ammonia.
    Dose the FC up to 10ppm (use PoolMath), wait 10-15 minutes, retest FC and CC, repeat until the CCs drop and the FC starts to hold.
    Then add 30ppm of CYA and follow the ShockLevelAndMAINTAIN Process.
    Although I highly recommend you read these so you understand some of the chemistry before you start:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Welcome!
    What he said ^^^
    I got as far as the test results before I suspected Ammonia as well.
    May 2016
    Bristol,CT
    34
    Welcome to TFP!!
    Two gallons of "mega shock" and then I saw no change in FC on a stick. The next day I and four gallons of bleach. Still no change. That was on May 31 and June 1.
    Remember, I'm a noob so don't beat me up too much!
    38,271
    Well if the mega shock was liquid, then it was likely just stronger bleach.
    Follow the instructions in my previous post ... report the FC and CC readings here each time.
    May 2016
    Bristol,CT
    34
    Thanks for the quick replies!
    Ok to raise FC with 68% Calcium Hypochlorite? I just put 3 lbs in. I will retest in the AM as it is dark here.
    38,271
    It will add CH, but it appears your might be pretty low anyway.
    Waiting overnight will not help with the ammonia determination.
    Aug 2014
    Northern IL
    4,615
    Also, you can use a 10ml water sample instead of a 25ml. Each drop is multiplied by 0.5 or total count is divided by 2. Same thing. The directions are inside the lid of the kit. It will use less reagents.
    May 2016
    Bristol,CT
    34
    After 3 lbs 68% Calc Hypo
    FC 1
    CC 5
    38,271
    Target 10 per per million again
    May 2016
    Bristol,CT
    34
    5 more lbs of CalcHypo
    FC 7
    CC 2.5
    Aug 2014
    Northern IL
    4,615
    Btw, glad you decided to brave the dark and start tackling this thing!
    What is the percent of your cal-hypo?
    May 2016
    Bristol,CT
    34
    Quote Originally Posted by MarianParoo View Post
    lol, I kissed the wife goodnight. If you guys are willing to help like this in real time, I will put in the effort. I want the pool clear! I need to get this system down as I have a large party July 9. I want this pool sparkling!
    cal-hypo 68% from Doheny's
    May 2016
    Bristol,CT
    34
    Added 3 more lbs and tested no change. Just threw in another 2. Total of 12 lbs of 68% cal-hypo so far. I'll give it 30 minutes.
    Aug 2014
    Northern IL
    4,615
    Guess you already said 68%. My bad for missing that.
    Can you do it one more time? You are right on the cusp.
    Cross-post. I will try to stay online as others seem to have retired for the evening.
    Good for you for fighting this thing. Do you have CYA on hand ready to go when you start holding chlorine?
    May 2016
    Bristol,CT
    34
    I will test in 10 minutes. I have 7 lbs of stabilizer on hand. Enough?
    I am I just reporting FC and CC. Or should I be testing other numbers?
    Richard320's Avatar
    Jan 2010
    18,984
    Quote Originally Posted by Varmint View Post
    No, just Fc & CC. You pH shouldn't have changed in so little time.
    6 pounds of CYA ought to be enough. That'll get you to 29. When you test (in a few days), it'll show as 30ish, which is perfect for a SLAM. Just assume it's in there once you add the sock. Yes, sock. Or nylon. Don't just pour it in the pool or in the skimmer.
    May 2016
    Bristol,CT
    34
    That's a big sock! Can I dissolve it in a bucket? Going to test now.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Just test FC and CC.
    According to Poolmath 7 lbs of CYA stabilizer will raise CYA by 34 ppm in 25k gallons.
  20. Back To Top    #20
    May 2016
    Bristol,CT
    34
    FC 5.5
    CC 3.0
    WHAT?
