Thread: first opening
    Jun 2016
    Gloversville, NY
    8
    first opening
    Hi all,
    I ordered the Tf100 test kit today. I raked the bottom of the pool for about 2 hours, I realize that I will have to keep doing it. The pool has been closed for 3 years and is a green swamp. I cleaned out the old sand from the filter, totally dissasembled the filter, cleaned the laterals, broke 2 in the process so I bought new ones. Refilled the filter with new sand... it took 1000lbs. The head space is correct.
    My question is: Will filtering my swamp water ruin the filter media? The "pool guy" said that he wanted to totally drain my pool and refill it. He said that clearing this water will ruin the sand and that I would have to do all that work again... thanks in advance.
    Don
    60' X 20' in-ground with a Triton II TR 140 sand filter, a Pac-Fab Challenger 2 1/2 hp pump, a Hayward cl 200 chlorine feeder.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: first opening
    If the pump is good you can recirculate until the water is clean enough to filter.
    You won't "ruin" the sand by doing anything. Filtering really swampy water will be nearly useless as the PSI will increase very quickly.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
