Thread: Pentair part name?
    Oct 2015
    San Diego, Ca.
    648
    Pentair part name?
    I saw a Pentair part on YouTube. It holds the vacuum hose in the skimmer hole so it doesn't pop out when the pump turns off.
    Does anyone know the part name or number?
    Thanks
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Pentair part name?
    If you could link the youtube video, that would help.
    Isolated Spa - 345 Gallons
    Feb 2014
    Central Minnesota
    5,080
    This part that would likely screw into the bottom hole of your skimmer and allow you to attach the hose to the barbed end of the fitting might work?
    Hayward Qk Disconnect-1 1/2mip Wg (sp1493) - INYOPools.com
    Oct 2015
    San Diego, Ca.
    648
    Found it. It's called a a Locking Bar.
    Aug 2015
    Folsom Prison, CA
    124
    Philo, that is part of a system called the Vac Plus II. I don't think the locking bar alone will do much for you, as the bar is supposed to hold the Vac Plus cover on top of the skimmer basket. I am not sure on that though. I have a Vac Plus system but couldn't get it working with my setup.
    Jeff || 19,000g IGP || SwimClear 3025 Cartridge Filter || Hayward TriStar 1.39 THP pump || K-2006 Test Kit || 80% Surface Coverage Heliocol || Hayward Controller || Hayward Phoenix 4X4 || "Solar Rings" || PoolSkim
    Oct 2015
    San Diego, Ca.
    648
    Thanks
