Thread: Do I also need to test my hot tub?
    May 2016
    CA
    29
    Hello,
    We have a hot tub with spillway so water flows out to the pool. Spillway is on for an hour each day to cycle the water through. Do I need to be testing my hot tub or is it ok since the water from the pool cycles through anyway?
    Thanks!
    Pool finished in March 2016, 25k gal, white plaster IG pool, Pentair Clean and Clear Plus Cartridge Filter, Pentair Intelliflo 2 VST Variable Speed Pump, Polaris 280 Pressure Cleaner with Pentair Booster Pump, Natural rock waterfall with Pentair Waterfall specialty pump, Spa: Mastertemp 400 High Performance Heater, TF-100 Test Kit
    38,290
    Re: Do I also need to test my hot tub?
    The spa water should be homogeneous with the pool water if you are having it spill over daily.
    May 2016
    CA
    29
    Thank you!
