Help Making Sense of Bottom Return/Main Drain
Aug 15, 2015
18
Lawrenceville, NJ
Hi Everyone,
I bought a house with an inground pool 2 years ago, and for the most part, I think I understand the equipment around the pool.
One thing I'm most confused about is the main drain/return (shown below). I had a local pool professional out last year to close the pool, and he mentioned that the main drain wasn't hooked up. I think he was attempting to lower the water using the main drain, and had to use his own pump instead. I wish I asked more detail at the time, but it didn't really occur to me to ask what that meant.
When the pump is running, it does return water, along with a single wall return in the shallow end.
I have never witnessed it appear to take in water. But I don't know if I've ever truly isolated the drain to see if it can. Below is the valve for the intakes:
The pool has two skimmers (1 at the shallow end and 1 at the deep end). Both are functioning properly at this setting. I can switch the valves to verify that both of them can take in water independently.
So here are my questions:
1. If the main drain/return were actually functioning as a drain, would I see another port in this valve for the drain?
2. Could the main drain be connected to the same port as one of the skimmers?
3. Is there a way to isolate the main drain to see if it's actually connected to work as a drain?
4. Do dual purpose fixtures (main drain/bottom return) actually exist? or am i confusing the two?
I'm really looking to determine what this fixture does (whether a main drain, bottom return, or both) and if it can function as a main drain, is it broken? or was it never hooked up that way?
Thanks in advance!
Dave
So is the valve in the picture for selecting each skimmer?
1/2. Look in the bottom on the skimmer. If you see 2 open ports in 1, then that could be where the floor is plumbed in to.
3. If it is plumbed to the bottom of a skimmer, then a float diverter can be used to pseudo-isolate the floor drain.
4. I think I have heard of them, but not sure I see the point.
The square knob is the top of a pvc plug that closes off that hole, i.e. neither skimmer is connected to the main drain (in a typical manner anyway).
"I can switch the valves to verify that both of them can take in water independently." This is confusing me - have you done this? When you turn the valve does one skimmer stop sucking while the other keeps pulling water?
Sorry for the confusion. Yes, when I turn the valve, one of the skimmers stops while the other keeps pulling water. This works for both skimmers. Thanks for your answer.
So the floor might be plumbed to the bottom of one of those skimmers. And then either the plug was left in after a closing accidentally, or it was plugged up due to a leak in the floor drain plumbing.
You might need to get down on the bottom and pull the drain cover to see if it is plugged down there too.
So it could be that the piping to one of the skimmers is tied into the main drain directly rather than via the other hole in the skimmer or is just accidentally plugged like Jason mentioned. One way I would guess to test that, if you can can isolate the suction piping is to:
- hook up an air compressor up to a drain plug fitting on your pump basket
- set air compressor pressure regulator to 15 psi
- isolate skimmer "A" using hayward valve
- blow air through piping (should blow water out of skimmer A)
- then plug skimmer A hole to see if any air is directed to the main drain
- if you see bubbles at main drain, they are piped together (somewhere)
- if no bubbles, then switch hayward valve to other skimmer and repeat procedure
Others can elaborate if there are any risks in this plan.
Again, thanks everyone for the replies. Talking this out has been very helpful. I work in technology, and often recall seemingly obvious and useful information only after I've finally asked around for help.
Case in point, I replaced the pipes between the skimmers and the pump last year. It was a DIY job...when I bought the house one of the pipes was crushed.
So there's definitely nothing connecting the skimmers to the grate at the bottom of the pool.
Is there any other way that the grate at the bottom could be a drain? Or can we conclude it's just a return at this point?
Can you clarify this: "When the pump is running, it does return water, along with a single wall return in the shallow end."
Water comes out the grate at the bottom of the pool?
Yes, water comes out of the grate at the bottom.
Then it's not a drain. It's a return. It was fashionable some tears ago to send the return through the drain when running the heater since hot water naturally rises.
You won't be able to use the drain for suction unless to dig up and cut pipes and replumb things that way.
I don't see any disadvantage to the way it is now. Many people have no main drain, and those of is that do quickly discover they don't work very well to draw away debris. ABout all they're good for s to move some water down deep to prevent temperature stratification, and your setup does that.
