Results 1 to 10 of 10
Thread: Tri-Chlor and CYA
    Fayetteville, Arkansas
    220
    Tri-Chlor and CYA
    Has anyone figured out a way, short of replacing water, to keep the CYA levels from increasing higher and higher as the season progresses? I'm using stabilized Tri-Chlor 3" tabs.
    Apologies if this topic has been posted before or stickied somewhere.
    Thanks -
    20x40 30,000 gal IG Liner, Pentair II Sand
    26venus's Avatar
    Jul 2013
    Shenandoah Valley, VA
    48
    Re: Tri-Chlor and CYA
    To put it in the simplest terms I can...you need to stop using Tri-chlor, Di-chlor or anything else besides plain old bleach to sanitize your water.
    16 x 36 IG Vinyl, 20,000 gal, chlorine, built 2001
    Hayward 3/4 HP Super Pump
    Hayward Pro Series sand filter S210T
    All in with TFP , testing with tf-100
    Donldson's Avatar
    NW Ohio
    2,893
    Replace water or don't use trichlor, those are your only options.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Ncdamsel's Avatar
    Jul 2015
    Garner ,NC
    65
    Quote Originally Posted by Rangerman View Post
    Thanks -
    stop!!!!!!!!!! " I'm using stabilized Tri-Chlor 3" tabs."..........STOP DOING THIS AND USE GOOD OLD BLEACH!!!
    13,995 gallons 24 X 52 / above ground pool.../.SWG/ sand filter/ vinyl liner
    Aug 2014
    Northern IL
    4,615
    The reason people are nagging on you is because those tabs actually keep raising your CYA. Most of us use plain old bleach or liquid chlorine which has no CYA in it. We get our CYA in a good range and then dose our FC accordingly. See this: Pool School - Chlorine / CYA Chart
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,237
    Sounds to me like a retired butcher walking into his old shop and asking for tofu
    Who ya gonna call? Chlor-busters.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    220
    Message received LOUD AND CLEAR. I have used bleach in the past. Honestly, I just got tired of lugging those jugs around. One fell over once. It leaked and destroyed the carpet in my Tahoe. OK, so . . . till something comes along to prevent the increased build up of CYA, I'll go back to juggin' it. I've been adequately corrected.
    220
    Just as a follow-up to being thoroughly chastised for falling from TFP grace by using tabs, I discovered one of our Wal-Mart stores is selling 10% Liquid Chlorine this season for $2.50/gal. A five-gallon 10% from a local chemical company is $35.
    38,275
    Tablets can be used in limited circumstances without issue ... like in areas with short seasons, where they partially drain for winter, and/or get a LOT of rain to dilute the CYA build up.
    Donldson's Avatar
    NW Ohio
    2,893
    Yes, I believe the chastising got a bit excessive, especially with this little tidbit: there is nothing in TFP that prohibits the use of pucks. TFP is about knowing what is in the stuff you put in your water and following the FC/CYA chart. Pucks are generally a bad idea because it starts to get out of hand as the CYA rises, but if someone is completely OK with the necessary water changes then the use of pucks is their business. It is something that annoys me a bit that people believe you MUST use liquid chlorine. It is by far the best option as it does not add anything but chlorine and salt, but that doesn't make it the only option.
    However, there are no magic CYA-free pucks (there are cal-hypo sticks but they require a special feeder and then you have the CH rising problem) and no magic potion that makes CYA disappear (despite BioActive's claims). If you use pucks you have to reduce your CYA through water dilution, no way out of that. If you can't change the water and want to avoid lugging jugs you can opt for an SWG or use lithium-hypochlorite instead. Lithium-hypo is insanely expensive compared to liquid chlorine but is an option.
