Results 1 to 10 of 10
Thread: Georgia New Build Quote
    Jun 2016
    Newnan
    2
    Hey guys! I am brand new here to TFP and new to ownership of a pool. I was hoping to run a quote by some folks with plenty of experience and receive your thoughts and opinions. We are currenty looking at a lagoon style vinyl liner salt pool. We are bouncing back and forth between a 18x35x29 and a larger 22x40x34. Any info you could pass my way would be greatly appreciated! Also any pics you may have of similar pools would be great to see a finished project. Thanks in advance!
    Quote:
    18x35x29, 700 sq ft concrete wall $26,700
    8 ft tanning ledge w/ steps $1,900
    9 ft bench/swimout liner over $950
    95 Ln ft cantilever coping (Included)
    1000 sq ft standard finish concrete$5,500
    Pentair Equipment:
    1 Super Flo (Included)
    1 Cartridge Filter (Included)
    1 Booster Pump and Pentair Legend II Cleaner (Included)
    1 Screen Logic Smartphone Remote (Included)
    1 Easy Touch 4 Computer w/ Salt (Included)
    4 LED Lights Low Voltage (Included)
    1 3 year warranty on all equip.
    Total: $35,050
    For the larger pool:
    22x40x34 940 sq ft the price goes to $39,150
    38,489
    Re: Georgia New Build Quote
    Welcome to TFP!!!
    Get at least a 2-speed pump if not a VS pump.
    Get a large filter (what size cartridge?)
    Ditch the booster pump and cleaner ... get a robot instead
    Make sure the SWG is sized for 1.5-3 times the volume of the pool
    Not sure I have ever seen someone regret getting a pool that was "too large"
    What are the volume of the pools? That is used to size the filter and SWG.
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    It looks like you are going to have a very nice pool! I can't speak to the cost but a couple of things that I learned from this forum: Ask about the size of the SWG. We have a 20,200 gal pool and have the IC40. If you are going to add anything like landscape lighting etc, I would ask them to price the Easy Touch 8. It allows you to control pool lights, landscape lights, etc. We have a variable speed pump and I really like that option as I can program speeds for waterfall, cleaner, skimming, filtering, etc.
    Best wishes on your build!
    18x36 kidney 20,000 gallons IG vinyl. Pentair Easy Touch 8 w/IntelliChlor IC40. Triton II TR100. Pentair Intellifllo Variable Speed. Waterfall/Jump Rock. 2 Pentair Intellibrite lights. TF-100 Test Kit. And a very happy husband who gets to play in the pool without having to take care of it.
    Jun 2016
    Newnan
    2
    Thank you so much for the insight guys. I will look into these details that you mentioned. Again, I am very new to this and I am learning a little bit here and there.
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    The only thing I can advise you on is to get absolutely the most decking around the pool as you can afford. If you only get the 3' surround you will regret it down the road.
    Mar 2013
    New Hampshire
    351
    Quote Originally Posted by YippeeSkippy View Post
    I agree with this but that quote says 1000 sq ft of concrete so that is way more than 3 ft all the way around I would think.
    18k: IG: Black Granite Liner: Aspen: 16x33.5: SWG: Polaris 280
    My pool build new-pool-build-in-nh-t60957.html
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,545
    Sig452,
    Some of my comments have already been mentioned, but I'll say them again.
    Do not get the Superflo. I suspect what is quoted is the single speed, but even the VS model is just a regular motor with a controller. You want the Intelliflo which has a Permanent Magnet Motor which was designed to run a slow and almost silent. Yes it will cost a little more but well worth the money.
    Filter, I suspect the included filter is the smallest one they have, which means you will be cleaning it once a month. Go with the biggest cartride they have and you will only have to clean it once or twice a year.
    The EasyTouch4 is really only an EasyTouch '3" because one of the relays is dedicated to running the SWG. The two other relay circuits will be used for the pool light and for the Pad light, so now you have an EasyTouch "1". And if you are unfortunate enough not to dump the Booster pump, you'll use the remaining relay for that. Not critical, but now would be the time to get the EasyTouch8 so you will not run out of control circuits the day your pool is built.
    Dump the Booster pump and Legend, and buy an Electric Robot cleaner like the Dolphin S300.
    Make sure the SWG they provide is at least an IC40, or better yet, the IC60.
    When they wire the EasyTouch demand that they wire it for at least 60 Amps. You never know what you might want to add in the future.
    Good luck with your new pool.
    Feb 2016
    Atlanta, GA
    145
    Welcome !
    I grew up in newnan!
    I vote for the larger pool - you won't regret it and the cost difference is small in the long run.
    Jun 2016
    millersville, maryland
    4
    Study up on salt vs chlorine pool. The salt generator produces chlorine and uses a considerable amount of power to operate. Salt breaks down everything it can get to including grout, metal and anything that it can oxidize. Ph must be watched close with salt. Salt water pools tend to develop scaling requiring mechanical removal. The water is softer with a salt water pool. (people like the feel)Chlorine can be a dangerous chemical. There are some health effects due to chlorinated pools but I think with proper water balancing these are minimal. I hear the cost of operation of a salt water pool is less than chlorine but i question the logic. I was considering the switch to salt water and found that most of the website are pushing salt water pool and leave out some important information. i.e. cost of electric for generator operation, cost of servicing generator (needed every few seasons for scale buildup on plates) Cost of chems for salt addition and ph adjustment.
    I spend maybe 300 per year for chems.
    Get large capacity filter. (what ever type you get) I upgraded my filter to get a faster turn over rate of capacity of my pool and its so much easier to maintain. They started me with the bare minimum filter that would work. I have cartridge filters.
    38,489
    Quote Originally Posted by Busterdan1 View Post
    Lots of bad information here. A SWG pool is a chlorine pool, the SWG just generates the chlorine instead of you having to manually add it.
    SWG does not use much power.
    There is salt in every pool and the SWG levels are still 10x less than the ocean ... very little if any damage to grout or metal can be attributed to the low salt levels found in SWG pools.
    Scale only forms if you are not maintaining the proper chemistry (as is required for any pool).
    The cost of maintaining a SWG pool is basically the same as a regular chlorine (bleach) pool over the long term ... including accounting all the things you mention.
    I do agree that large filters are better
