Thread: Suggestions for Above Ground Pool Light (add on)
    Jun 2014
    Killingworth, CT
    21
    Does anyone have a suggestion for an add-on light for an above ground pool?
    I'm looking for the type that can be hooked up on the fly when you have company for an evening party. We have a full deck around our 30' above ground pool.
    So this would be something more of a magnetic type than a drill through the pool wall style. I'm ok with a wire going over the side of the pool to the light.
    Thanks for any suggestions!
    Chris
    30' Round, Hayward S180 Sand Filter w/ 1.5hp single speed Hayward pump
    Re: Suggestions for Above Ground Pool Light (add on)
    Quote Originally Posted by chrisj View Post
    Chris
    The temporary lights are all battery-powered and put out wee bits of light. Think kid's flashlight as opposed to backyard floodlight.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    Jun 2014
    Killingworth, CT
    21
    Quote Originally Posted by Geebot View Post
    Thanks for replying but I don't think that is true. I see at least a couple on Amazon that include transformers and are wired to drop in the pool without going through the wall.
    Nectarologist's Avatar
    Apr 2015
    New York
    428
    Try this type ("nightlighter"): Above Ground Pool 100 Watt Multi-Colored Light - In the Swim
    It's 12 v, the same as the in ground pool lights (I believe).
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
