Results 1 to 10 of 10
Thread: Chlorinator 320
    Oct 2013
    Houston, TX
    32
    Chlorinator 320
    My chlorinator does not show water flow (with the cover open) when I switch the pump suction valve to main drain position. It shows flow when the valve is switched to 'skimmers' position. I am not sure why this is happening. Any ideas? Thanks.
    38,394
    Re: Chlorinator 320
    Where the water is sucked from should not have any impact on the chlorinator (which of course we rarely recommend using anyway).
    Does the filter pressure change depending on main drain vs. skimmer suction?
    Does the return jet strength change?
    Please add your location (City, State or City, Country) to your profile and pool details to your signature as described HERE as it will help us help you.
    Oct 2013
    Houston, TX
    32
    Re: Chlorinator 320
    jblizzle, This old dog can learn a new new tricks. I added my signature along with other pertinent info. about the pool. Thanks for the suggestion. As I went back to look, the Chlorinator is not working. There is no pressure difference when switching from main to skimmers or halfway. I installed a new check valve at the suggestion of the pool store which did not help. I saw someone on youtube installing Pentair hi flow feed kit. It sounds like something I may need to try. I am still open for other suggestions/ideas.
    Andy49
    12K, IG, Plaster, DE, Install 1992, Spa, Polaris Sport, Rainbow Chlorinator 320, Taylor 2006
    38,394
    Re: Chlorinator 320
    In Texas I would ditch the chlorinator altogether and get away from using Trichlor because the CYA is going to climb until you have to replace water.
    22,551
    Re: Chlorinator 320
    I agree with JB that you should think about another mode of chlorination, but lets see if we can get the feeder working since it's already plumbed. Then you could at least use it for vacations, etc..
    Has the feeder ever worked?
    Does the pressure gauge go to zero when the pump is shut off?
    Are you sure it's working when on skimmers?
    Where in the system is the feeder plumbed?
    Is the flow arrow pointed in the right direction?
    If you take the tubing loose at the feeder does any water flow out of it?
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Oct 2013
    Houston, TX
    32
    Re: Chlorinator 320
    another mode of chlorination- I assume that somewhere in the forum there are posts on alternate mode of chlorination. I will look into it.
    [/COLOR][/COLOR]Has the feeder ever worked? Yes, for the longest time. I replaced the tabs regularly
    Does the pressure gauge go to zero when the pump is shut off?-Yes
    Are you sure it's working when on skimmers? It is not. It was temporary
    Where in the system is the feeder plumbed? On the discharge side after the heater and before the three port valve directing the water to either the spa or the pool.
    Is the flow arrow pointed in the right direction? Yes
    If you take the tubing loose at the feeder does any water flow out of it?-Yes
    Thanks for your help.
    Andy49
    38,394
    Re: Chlorinator 320
    22,551
    Re: Chlorinator 320
    When you replaced the check valve did you make sure to install it in the correct orientation?
    Did you clean out the base when you had the check valve out?
    Have you checked to make sure the valve at the bottom is opening when you turn it?
    Oct 2013
    Houston, TX
    32
    Re: Chlorinator 320
    I have taken the DE filter apart. So now is the time for me to remove the chlorination and inspect it to see if I see anything unusual.
    Andy49
    Oct 2013
    Houston, TX
    32
    Re: Chlorinator 320
    Good news. I lubed everything and used silicone adhesive at small screw on fittings. The chlorinator is working now. It's time get the yellow out now.
    Andy49
