Thread: New Slide, where to place?
    Jun 2016
    Acworth, GA
    44
    Looking to place on the left side of this picture. Was thinking of putting between shallow end and deep end on the slope. Any suggestions?
    ~33000 gallon, IG, vinyl pool, 3 1/2 foot shallow with ~10 foot diving well built ~1985. Old Hayward side mount sand filter, with new Hayward Multiport SPX0710X32 replaced 5/2016. Pump and Motor replaced 5/2016 with Pentair WhisperFlo 3/4 HP Fluid End pump (WFE-3 part# 075452 Inyopools) and Century Centurion 3/4 HP motor, B2847. Leslie's simple test kit / taking sample to Leslie's, New Dolphin pool cleaner, No well, No Water restrictions
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: New Slide, where to place?
    I think a right turn slide placed on the left side of the pool so that the exit of the slide dumps in the area where the bottom slopes down would be best. Maybe 1/3 of the way down the slope or middle of the pool side length. It's hard to make out, but you can see our slide location in my avatar. Our pool is nearly identical dimensions to yours, but with end steps and ladder opposite the slide.
    I don't have any really good pics of our slide location but from this one from another thread: Refinishing slide - Page 2
    You can see in that picture, the wall anchor/loop in the coping is where the slope downward toward the deep end starts. So the ladder part of our slide is next to the shallow end, but the exit of the slide dumps onto the sloped area. Hope that helps a bit.
    Isolated Spa - 345 Gallons
    Jun 2016
    Acworth, GA
    44
    Any suggestions on how to get water to it. I was looking at this spray kit from home depot.
    Poolmaster Spray Kit for Pool Slide-36631 - The Home Depot
    Feb 2014
    Central Minnesota
    5,080
    What kind of a slide is it? Do you have any pictures of it or a link to it on the web?
    If your slide is the same style as mine, that kit will work. Plan on replacing it every few years though as the plastic tubing tends to get brittle and the fittings degrade in sunlight over time. I'm currently working on a DIY sprayer kit with brass fittings and trying out some different styles of tubing to see if I can find a set up that lasts longer.
    The other issue is getting water to the slide. My pool has a 1 inch plumbed line underground controlled with a gate valve at the equipment pad. However, before I moved in, it was not properly winterized at some point and has cracked somewhere underground. If I leave the gate valve open and run the water to the slide there, I lose about an inch of water every hour! I'm planning on just running a garden hose through the rock around the outside of the pool and just supplying it with a faucet on the outside of the house. Will be a good way to top the pool off periodically after evaporation. Some day I may get it hard plumbed in the pool circulation again...
