Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Newbie with Intex Pool - help needed...
    May 2009
    Lowell, MA
    19
    Hello All,
    This is my first post here but am having some issues. Year 2 just put up the pool and the ring has a small tear in it. I patched it this morning before work so hopefully it will be fine when I get home tonight. I have the 18' x 48" Intex Blow Up Pool ( I call it the Walmart Bag! )
    Anyway, I have bought a new filter (stronger one) although I don't have the info on it here. I used it last year and it blew out the cover where the water comes back into the pool. I don't think (know if) that that is bad but please correct me if I'm wrong. As I did leave it off for the rest of last year.
    My issue is with the floating skimmer; I can't seem to get it to stay down (in it's correct position not lying on it's side) it tends to want to float up and then I am catching air. Last year I actually zip tied the hose to itself in order for it to stay put which seemed to work but that to me doesn't seem correct.
    My main issue is when I have the pump on a timer and if i'm not there to catch it the basket floats up and will eventually break the filter. I have searched all over the internet and haven't seen this mentioned anywhere. Does anyone have a suggestion.
    My friend suggested placing a rock in the basket to help is stay put but again do I really want a rock in the pool. Thank you in advance for any help you can provide.
    18x48 Intex Blow Up (Walmart Bag); Intex Krystal Clear Model 633 Filter Pump; 7600 Gal.
    Re: Newbie with Intex Pool - help needed...
    Welcome to TFP!
    I would try a nice rounded river rock in the skimmer basket. You want something large enough that it won't fit down the pipe but not much larger than that.
    May 2009
    Lowell, MA
    19
    Thank you for your reply,
    I just can't see putting a rock in the pool but I guess I will have to do that. But I just can't seem to understand that no one else has this problem.
    The filter is Krystal Clear Model 633 Filter Pump. This thing blows some air back in the pool and as I posted earlier it blew the return cover (screen) right off. Is there something I should do or will it be okay to leave it off?
    Also the patch held up - Yay!!
    Thank you.
    May 2009
    Lowell, MA
    19
    Another question... My sister said something about wrapping the filter hoses in black electrical tape to help keep the water heated. Has anyone ever heard of this?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by jotrud
    I doubt that's going to make enough difference to be worth the effort.
    Crazycalvin's Avatar
    Mar 2008
    Irmo, South Carolina
    56
    We had that problem when we had an Intex pool. We put a couple of two inch stainless balls in a plastic container, filled the rest of the way with water, put the lid on, and tied the complete contraption onto the skimmer hose. I also second the opinion that the black tape around the hoses will not make much if any difference. Hope this helps get the creative juices flowing. Later, Calvin.
    15 x 26 Sharkline
    2.5 HP Dual Speed Pump
    200 Sq. Ft. cartridge filter
    May 2009
    Lowell, MA
    19
    Thank you for the reply, I am not sure what I have that I could use, however, creative juices running I am now thinking of the golf club weights that I bought yesterday, I could do something with those. Thank you.
    Also do you know with these pools is it possible to purchase a longer hose? edited - MikeInTN I was trying to hide the pump in the bushes but the hoses are just a tad two small. Maybe another 2 or 3 feet? I actually have extra hoses due to the fact that I purchased another filter, so can I hook those up together somehow?? And if so then it will be too long (You know never satisfied!!!) but that I can deal with.
    Also I hate to be a pain but I think the Walmart bag is kind of yucky to look at, do you know or have you seen any pictures trying to hide it or spruce it up or what kind of plants would you suggest to place near the pool?
    May 2009
    Lowell, MA
    19
    I should have mentioned that I live in Massachusetts. Thank you for any help.
    May 2009
    Lowell, MA
    19
    Ok so I am going to be a pain.. I keep looking at this pooldevil and think that it is something that I may want to purchase. Do you know if it will fit the pool right out of the box or are there attachments and stuff that I would need to do? Again thank you for all your help.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Before I moved away from Houston, I had an 18'x48" Intex inflatable-ring pool with the 'can' skimmer also. What I found was that there was always some twist to the flex hose which kept the skimmer from sitting at the right attitude. I could rotate the tubing a bit and make it work. I would grab the flex hose just below the can, and twist it a little on the can fitting and actually adjust the positioning of the skimmer like that. With the skimmer can hanging about 10" or so away from the fitting in the side of the pool, I could make it angle forward or back or however I wanted it.
    May 2009
    Lowell, MA
    19
    Hello All, Back again.
    I have just tested with the T100 test and these are the numbers....
    FC = 3.5
    CC=0
    Chlorine = 3
    BR = 6
    Ph = 7.2
    Are these ok?
    Jan 2009
    Cupertino, CA
    1,966
    If you don't use bromine, ignore the "Br" number.
    The TF100 has several more tests and we like to see all the results: TA, CH, CYA. Without CYA we can't tell whether your FC is okay. TA and CH will help us figure out if you might have scale or pH issues.
    --paulr
    BBB "Intermediate Swimmer"
    May 2009
    Lowell, MA
    19
    TA = 60
    CH - I didn't think I had to do CH because it is a vinyl pool
    CYA = The black dot didn't go away
    Jan 2009
    Cupertino, CA
    1,966
    Vinyl doesn't care if it's low but you can still get scaling if it's too high. Sometimes fill water has high CH. In Mass. it's unlikely to be high but it's worth doing the test once. Note the CH test is very slow, really swirl 20-30 sec between drops.
    You need more CYA; shoot for 30-50ppm.
    --paulr
    May 2009
    Lowell, MA
    19
    CH = 100
    Is that ok
    Jan 2009
    Cupertino, CA
    1,966
    pH 7.2, TA 60, CH 100, should be fine. Keep an eye on the pH you don't want it any lower than that, keeping it stable at 7.5 seems to work best. If your pH tends to drop then you should increase the TA.
    --paulr
    May 2009
    Lowell, MA
    19
    To be truthful I have only added about 3/4 bottle of bleach last night and that is all that has been in it since last Sunday. The pool is very clear and I will add stabilizer but is it ok to swim in today before I add the stabilizer? Although still at 68 degrees it may not be an issue.
    I am starting the BBB method (since last night)
    Jan 2009
    Cupertino, CA
    1,966
    Sure, you have chlorine in there, swimming is okay. The CYA can take up to a week to dissolve, don't bother testing it again before then. But after it has been in there a day or so, you can start using your target to figure out the appropriate FC level from the Chlorine/CYA chart.
    --paulr
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    As long as your FC's between 1 and 3 for your CYA=0, then you're good to go swimming. 1-3 is the normal range and 10 is the shock level, so I'd hop in even if the FC was up to around 6 or 7 or so. Enjoy!
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
  20. Back To Top    #20
    May 2009
    Lowell, MA
    19
    Thank you both for your help. I hope to enjoy although it is still very cold... but it is hot out so maybe just a toe or two... Again thanks.
