Thread: possible skimmer leak repair
    Diver's Avatar
    May 2011
    South of Boston
    450
    I have a hayward wide mouth skimmer in my inground pool. Previous owner used tabs in the skimmer exclusively and I think years of leaching out high chlorine water made a number on the liner directly below, it shrunk and now I have visible rips right under the skimmer plate.
    I used pool putty to fix it to some extent so at this point I don't have pictures of actual problem. But here is the schematics
    [/URL][/IMG]
    The liner is 15 years old and degrading fast so it will have to be replaced in few years. I was thinking to attempt a fix for the skimmer leak at the end of this season hoping to get a leak free year or two...
    So I was thinking to buy a piece of liner or clear vinyl patch material and cut it few inches larger than skimmer face plate. I would take the plate off, glue the patch to the liner overlapping the tears, replace the gasket and put the plate back. Something like this:
    [/URL]
    I have few concerns and maybe some knowledgeable folks can share some thoughts..
    1. First concern is that there could be some tension on the liner and once I take all the screws off it will pull down far enough making repair impossible. I repaired few tears right under the liner track and there didn't seem to be any tension. So I hope that I would be ok here as well. I could leave 1 bottom corner crew in, undo the others, swing the plate off, put some other screws back in. This way at least one screw will hold it. Which it also might not and the liner will rip off of it.
    2. There is also a possibility that the fix will make it all worse. Nothing I can do beside trying to do the best job I can.
    Any advice, thoughts on overall approach? And is clear thin vinyl repair plastic better than actual liner for this kind of repair?
    26K In-ground Vinyl Pool | Hayward DE4820/SP0710XR50 filter | 1.125 HP Dual Speed Hayward Super Pump | Aquasol Solar
    30,426
    Re: possible skimmer leak repair
    Pretty difficult to get a good glue job on a peice that large. For sure you can try it but I would be ready to put in a new liner if it failed.
    There won't be any tension.
    Diver's Avatar
    May 2011
    South of Boston
    450
    Dave,
    I thought I would try to glue it in section. One piece, but glue one portion at the time. If there is no tension, the it would be hard to make it worse, right?
