Results 1 to 17 of 17
Thread: Ph rises overnight
    May 2016
    Glendale, Az
    74
    Ph rises overnight
    Last nite I did a test for FC and Ph. The resultys were
    Ph 8.2+
    FC 2
    I added the necessary MA and Cl and retested
    PH 7.8
    FC 6.5
    This morning after running the pump all night I got the following
    PH 8.2
    FC 5
    I lose 75% fc during the day. Is the continuous high PH causing this? I will be doing a full test tonight..
    15,000 ig, pebble tech,sand filter,remodeled in 2007. Glendale, Az
    TF100 w SpeedStir
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Re: Ph rises overnight
    Quote Originally Posted by az240z View Post
    PH 8.2
    Any water fall? SWG? or suction side air leaks that might be causing the water to aerate while running the pump? (Do you see bubbles coming from returns?)
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Sep 2015
    Rome, NY
    363
    what's your TA?
    Pool installed 8/2015. 30' round Radiant pool. 21,000 gallons. 200# sand. Hayward Vari flow XL valve. 1.5hp Hayward Power-Flo Matrix running 10 hours/day in two periods. TF100 with speed stir. Sun all day, south side of house
    Order test kit TF-100 w/ Speed Stir and then Poolmath Calculator --- RECOMMENDED LEVELS --- POOL SCHOOL --- Algae? --- Chlorine/CYA CHART.
    May 2016
    Glendale, Az
    74
    Quote Originally Posted by mikemass View Post
    No none of these..
    TF100 w SpeedStir
    May 2016
    Glendale, Az
    74
    Quote Originally Posted by doc8404 View Post
    what's your TA?
    TA is 120
    CYA 60
    TF100 w SpeedStir
    Jul 2015
    Tempe, AZ
    194
    Yeah - do the full tests. CYA too.
    My guess is TA is really high which drives up pH.
    And you shouldn't be losing 1.5 ppm FC overnight either. That's an indicator that something else (algae?) is probably going on.
    ETA - you beat me to it.
    John - 16,000 gallon | in ground | pebble | Triton II sand filter | TF100 | speedstir | Hayward Phoenix 2x
    Jul 2015
    Central Valley CA
    1,107
    Your TA is a bit high and pH of 7.8 is on the upper end of the recommended scale too. Try pushing your pH down to 7.4 and see if you can keep it around 7.4 to 7.6, if you do that the TA should come down in time, I keep my TA in the 60 to 80 range and pH seems to be much more controllable. If you want to actively push the TA down there is a link in pool school with a process to do that.
    Also a FC loss of 1.5ppm over night could be a concern you might have something growing in the water take a look at the SLAM process in pool school and look at the OCLT test criteria. You might want to preform the OCLT test tonight just to be sure things are as they should be.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Jul 2015
    Tempe, AZ
    194
    That TA is high enough to drive pH up quickly.
    Work this plan: http://www.troublefreepool.com/conte...tal-alkalinity
    My pool is way happier with a TA around 70. pH hovers around 7.5-7.6. The TA will rise throughout the summer with our high TA fill water. I had my down to 70 in April and by last weekend it was up to 90. So I used the process linked above to get it back down to 70.
    You should also run another OCLT tonight and be prepared to SLAM. http://www.troublefreepool.com/conte...loss-test-oclt Losing 75% of FC daily and 1.5 ppm overnight likely means something is consuming your FC.
    And I would prioritize the OCLT and FC issue over the TA.
    ETA: And now someone else beat me to it...
    Jul 2015
    Central Valley CA
    1,107
    Quote Originally Posted by Cinic View Post
    Happens to me all the time , it's usually Richard320 doing it to me dude has some ninja typing skills
    Jul 2015
    Tempe, AZ
    194
    Quote Originally Posted by atttech-2 View Post
    At least we all think the same. He'd get 3 different answers if he went to two pool stores.
    May 2016
    Glendale, Az
    74
    Thanks for all the suggestions. I can't slam until Sunday as company is coming for the weekend. I know some slams should take 3 days, so I may put it off till next Friday when I have 3 days to test.. I will start the TA tonight..
    TF100 w SpeedStir
    Jul 2015
    Tempe, AZ
    194
    Many SLAMs take longer than 3 days too. I think mine took 8 or 9 days.
    Keep the FC on the high end until the weekend. Couldn't hurt - and you certainly don't want it to turn green or run out of FC and potentially have other nasties in the water.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I'd worry more about the falling FC than the rising pH. You don't want a cloudy and/or green pool for your guests. Drop pH to 7.2 and raise FC to 24 as soon as you can. You might be able to stop an algae bloom before its starts.
    May 2016
    Glendale, Az
    74
    aerator.jpgI adjusted the PH down to 7.2 and added 128 oz of chlorine. I also rigged up an aerator. It does about 150 gallons an hour. Fc is now at 12.5
    TF100 w SpeedStir
    May 2016
    Glendale, Az
    74
    Pool is clear
    FC 8.5
    PH 7.8+
    TA 110
    MY hose aerator lowered the TA by 10
    Losing that much FC means a slam next weekend..
    TF100 w SpeedStir
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    I like your aerator. What did you do? Hook a vacuum hose into a return line and reduce the other end into a garden hose?
    And by the way, your aerator didn't lower the TA. The acid (or whatever you used) lowered both the pH and TA. Then the aerator raised the pH w/o causing TA to come back up.
    May 2016
    Glendale, Az
    74
    Thank you for correcting me on the PH rise. I have a small electric pump that I'm using. Hooked it to the hose..
    TF100 w SpeedStir
