Thread: Seasonal Temperature/Use?
    We have been enjoying our tub since February.
    As the weather gets warmer do folks keep the tub temperature above 100 *F , set it lower, or just not use it.
    I searched here but was unable to find any info.
    350 gal Infinity using BBB
    Feb 2008
    Flower Mound, TX
    Re: Seasonal Temperature/Use?
    A family member with a spa down here in Texas where it gets plenty hot in the summertime tells me that she keeps the temperature turned down in the summer. It only takes a couple of hours or so to get it up to 99-100 with the cover on irregardless of the time of year. Mostly though, since she doesn't have a pool, just a spa, she leaves the heater off in the warmest months and will use it as a place to cool off. A sort of "micro-pool" if you will.
    10K gallon IG gunite with waterfall; Pentair CC320P filter; WhisperFlo 2 HP pump
    TF Test Kits - Pool Math - Pool School
    "It depends."- JohnT
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    I keep mine hot all year.
    Rocklin, Ca
    I turn mine down to about 90-95 in the Summer.
    11000 Gals, Intelliflo, Sta-Rite Cartridge, Polaris 360
    Pool I built in my old house: my-new-pool-build-t4534.html
    Alfred Beachport's Avatar
    Jul 2008
    Alameda, CA, USA
    I have a gas heater, so I let the spa cool between every soak regardless of season.
    Don't know where you are, Curmudgeon, but a 90-degree spa is very refreshing when we have a heat wave.
    Cheers, Erik
    320 gallon Beachport San Clemente octagonal fiberglass spa, RayPak Versa 155B heater, Pentair Whisperflo WFE-4 1HP pump, Sta-Rite 100TX cartridge filter, Len Gordon FF1000 controller, Mariah blower
    Pristine Blue with 30ppm borax, bleach and MPS shock
