Thread: Lesson learned-a word of warning
    Jun 2011
    Carbondale, Illinois
    62
    I have a SWG. Needless to say, outside of a green pool opening, I rarely have to deal with chlorine. When I do, I typically use liquid bleach. Last week I was sick with a stomach virus on top of being 6 months pregnant, so I was not able to monitor my water chemistry for about 5 days. I also forgot that my SWG was only set to 10%. That, coupled with several days of on/off rain, caused my FC to tank. By the time I was well enough to check it, I was at zero and I knew an algae bloom was looming. I cranked the SWG but I knew I needed an alternate source to get things up quickly.
    Not realizing I had liquid hiding in the shed, I went for a container of mini chlorine tablets so I could get something in there before I went to the store. It was a container from the end of last season. Something had taken place inside, and when I opened it (not near my face), I was met with a very powerful gush of chlorine gas. Let me tell you, I would not wish it on my worst enemy. The burning in my eyes, nose, and chest was so violent. I was very close to having my niece call 911, but calmed myself enough to call poison control. I could only get 2-3 words out at a time between coughing. They reassured me that an inhalant injury probably would not harm baby, and we discussed when or if it would be appropriate to go to the ER. After about 30 minutes in fresh air I was able to calm my breathing, but continuously coughed for 2 more hours before finally passing out from exhaustion and sleeping for an hour. After that, things were much better but I had discomfort with deep breathing for the next day or so.
    After allowing the open bottle to aerate, I cautiously examined it and noticed that some of the tablets appeared charred, but there was no indication of an abnormality on the outside. I am upset with myself for taking for granted that these are powerful chemicals--it was not properly stored and old. I should have known better. Please, if you are a pool care amateur, learn from me and be careful!!
    30k gal, IG plaster epoxy paint and stainless steel sides, built ~1980, sand filter, TF-100, SWG Circupool RJ-45, Dolphin M400.
    Re: Lesson learned-a word of warning
    Getting gassed is no fun. Thanks for the reminder to be safe.
    Always be wary when opening any chemical. Never open chemicals in an enclosed space. Do it outdoors and expect vapors. Make sure that the wind is blowing from you to the container
    Breathe in before removing the lid and then walk away when the lid is removed. Allow a minute or two before approaching the container.
    Support the site
    Welcome to the 2017 Solar Eclipse Crossroads. - 2017 Solar Eclipse
    Carbondale is in the path of totality for not one, but two total solar eclipses. The first total solar eclipse over the U.S. since 1979 will reach its point of greatest duration on Aug. 21, 2017, just a few miles south of Carbondale. The next solar eclipse will happen on April 8, 2024. The centerlines of totality for both these eclipses intersect over Carbondale’s Cedar Lake.
    How cool is that?
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    That is cool! Front row seat!
    Jun 2011
    62
    Yup, a lot of places are planning major viewing events! Pretty cool.
