Results 1 to 12 of 12
Thread: Ugh...cloudy pool
    Jun 2016
    Aston, PA
    4
    Ugh...cloudy pool
    Hello all, purchased a house in Feb with a pool (16' x 32', above ground). Was suggested to shock it, which I did on 6/2 and turn the pump on ( 5 gal). I also brought a water sample and purchased suggested chemicals. Long behold after I shocked the pool, the strainer was busted and I just purchased a replacement today (new pump and strainer). Chemicals were added and pump was installed around 9am.
    Long story longer...after I added chemicals (and shocked again because the first shock just sat with no water movement) and I discovered that there was still a considerable amount of leaves at the bottom of the pool and borrowed a friends leaf vacuum. Picked up a bunch of leaves, almost all from what I could see (which isn't much because it's so cloudy).
    After the pump running for about 10 hours, it's still cloudy.
    My water levels are where they are supposed to be so I don't need anymore chemicals buy how do I get the cloudy-ness to be gone!
    Thanks in advance!
    Jan 2012
    'burbs of Augusta, Georgia
    7,337
    Re: Ugh...cloudy pool
    Hey there KC4767 Welcome to TFP!
    First off, you don't need to buy any chemicals from the poo store. They're over-priced and rarely what you *really* need. What you need is BLEACH, BLEACH and more BLEACH along with your own decent test kit with the FAS-DPD chlorine tester in it. The TF-100 or the Taylor K-2006 (no other #) are both available on Amazon or thru TFTestkits.net
    Then before we can figure out what's wrong we need these test results:
    FC
    CC
    pH
    TA
    CH
    CYA
    all from your own test kit, NOT a pool store test.
    Have you read Pool School up top??
    Jun 2014
    15,093
    Welcome to TFP! I also recommend the TF-100 (XL Option) w/ Sped Stir.
    Also, please add your pool info to your signature by going to the top of the TFP web page (just under the Pool School button) and select "SETTINGS". On the next page look to the left for a menu bar that says, “MY SETTINGS” and go to "EDIT SIGNATURE" to enter your pool and equipment info there. It will help us later. This link may also help you: Pool School - Read This BEFORE You Post
    Great to have you with us.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    Great info thus far... after you fill in your pool details in your signature, we can give you some guidance on what you can do until you recommended test kit arrives.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Jun 2016
    Aston, PA
    4
    Good info to know! Is there a reason not to trust the pool store test kits?
    As far as the signature, I honestly don't know what I have besides a sand filter. The stickers are worn and faded, I can take pictures if that would help. I know the size and what type of pump I have. Anything more than that, I'll have to post pictures in hopes someone can identify it.
    Jun 2014
    15,093
    Several really:
    - Inadequate lighting skews the results
    - Seasonal hires who are not knowledgeable
    - Lack of personal attention to your pool and specific needs
    - Retailer's generated results designed to push products off the shelf - over-priced products
    - Inconsistent testing results
    You certainly can upload some pics. We'll help tell you what you should add to your signature.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    The pool stores generally don't sell good "full" test kits. They rely on people bringing in their water and testing it themselves (which is usually WAY off) and then selling you a bunch of chemicals you don't need.
    The TF100 and Taylor 2006c are really the only way to go.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    We will need the size (gallons). If you don't know you can use the calculator at the bottom of pool math: http://www.troublefreepool.com/calc.html If you have trouble estimating the size, ask questions.
    And we need to know your pool type (vinyl, plaster, fiberglass etc).
    Add what you know to your signature.
    Karen
    Jun 2016
    Aston, PA
    4
    Taylor complete water test kit ($99.99) was ordered....now I wait.....
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by KC4767 View Post
    What was the kit # K-XXXX
    Support the site
    Jun 2016
    Aston, PA
    4
    K-2006c
    16' x 32' oval, above ground pool. 13,700 gallons.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    You can safely add 1/2 jug of bleach a day. Wal-Mart has been running a $2.50 special on 10% bleach found in the pool/seasonal section.
    Brush every day, scoop out any debris, run pump 24/7. Post up a full set of results when you get your kit.
    Once you tackle this monster, you will always have clear water, never have to "shock" and the $ to maintain clear water will be much less than years past.
    Karen
