Thread: stenner injector/check valve leaking?
    May 2016
    Troy IL
    476
    Hi all. I finally got my Stenner pump installed at the pad tonight.I threaded the injector/check valve assembly into the T that I plumbed in for it, and turned the pool pump on before hooking up the hoses to make sure it didn't leak. To my surprise, water slowly bubbled up the injector tube. Is that normal? I suppose if water were to travel back up my tubes, the Stenner itself won't let the water back into my chlorine storage. But it seemed to go against what I know a check valve to do.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    Apr 2016
    Rockville MD
    43
    Re: stenner injector/check valve leaking?
    Sadly I saw the same thing with my new installation, and maybe it needs very high back pressure to seal properly. But I do think the chlorine supply is safe from pool water back-flow.
    20x35 in-ground oval. Wet Edge Luna Quartz finish. Hayes Super Pump with AO Smith V-Green 165 VS motor. Polaris 380. Enersol solar heating with automatic controller. Automated chlorination with Stenner pump.
    May 2016
    Troy IL
    476
    I suppose that makes sense. Perhaps it's the downside of choosing the higher psi pump. Either way, I appreciate hearing I am not alone. I'm setting up the timer for injecting now. If there are any problems I should know soon.
    Dec 2014
    Riverside California
    482
    I have had a couple of Stenner injector/check valves and they did the same thing. I think the rollers in the Stenner pump would prevent any back flow of water into the Stenner tank as the rollers are pinching the tube pretty good. If the feed tubing from the Stenner to the injector broke, I think the check valve would slow down the flow of water considerably. The "check valve" is a duckbill type and upon close inspection of it I don't see how it could seal 100% against pool pressure.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    May 2016
    Troy IL
    476
    Thanks Gary, that makes me feel better. I didn't really inspect mine when I had it apart, but I did take it apart to make sure the duck bill was in there and all. You are correct that it does prevent most of the pressure from pushing water out, so even in the event of a failure, I wouldn't lose much water.
