Thread: Intex Automatic Cleaner
    Greetings all. I just purchased the Intex robot and really like it. But since my liner has some creases that I wasn't able to get out, it frequently becomes stuck. My pool is off within the 1" tolerance, so I never fixed it. I am using the Intex 2100gph sand filter with a new salt water generator. Now onto my question.
    If I upgrade the sand filter to the 3000gph, or a Hayward that does more than that, would my cleaner not get stuck on the creases?
    Thanks all!
    Regards,
    Gabesdaddee
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Intex Automatic Cleaner
    It will probably still get stuck, but I am not positive... I would hate to see you buy a pump and it not work but maybe it's worth a try..
    Jun 2015
    Stockholm, Sweden
    250
    Try setting the filter valve on recirculate, bypassing the sandfilter. That gives an extra boost that may be enough to overcome the creases. Gives you an idea whether a new pump will solve it.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    Jul 2014
    Oakbank, Canada
    389
    Good idea!
    Quote Originally Posted by Mickelin View Post
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    mine flys in my pool...
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Sorry for not responding to this thread sooner...it's been one of those days. Turns out my son partially closed the return valve causing this issue. Now it doesn't get stuck at all. Thank you all again.
