Results 1 to 11 of 11
Thread: Solar Cover Evaporation
    I was just curious on peoples experience with solar covers. I still lose about a sliver of water a day. My cover isn't cut to fit the ladders. So it isn't totally covering the surface.
    16x32X8 Vinyl liner 21,000 gal.
    Hayward Pro Series S220T 250lb. sand filter hard plumbed
    Taylor K-2006 Test
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Solar Cover Evaporation
    It should reduce evaporation by quite a bit. More on windier, drier days. Are you noticing less than before cover?
    Have you confirmed that you don't have a leak? Pool School - Leak Detection
    Isolated Spa - 345 Gallons
    Yes way less. Just like 10th an inch is still evaporating a day.
    I just didn't know if for some people it stops it completely.
    Taylor K-2006 Test
    Probably 10th an inch in 2 days.
    Taylor K-2006 Test
    JoyfulNoise's Avatar
    May 2015
    13,226
    I just go by the sound of my autofill. With my cover on, it is quiet and there is no sound at all. When my cover is off, it sounds like a toilet bowl that is constantly running. Covers work AMAZINGLY well at cutting down on evaporation.
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    +1 to that and reducing FC consumption and PH rise!
    May 2015
    13,226
    Quote Originally Posted by pooldv View Post
    I've had mine off for over a week now. I left it on too long when the day time temps got high and nearly shot my pool water past 96F. It was like a bathtub.
    I haven't had a chance to put it back on because everyone is swimming in it.
    Matt
    DFW, TX
    24,497
    Nice! Water hit 88 today, it'll probably be coming off for good in a day or two. As soon as the lows move up from the lower 60s to the lower 70s.
    May 2015
    13,226
    Yeah. Our overnight lows are still hitting the high 60's with daytime temps near 100F. So my water temps average 86-88F and then overnight the air temp hits 68-70F.
    So I've got a 20F temperature differential and the relative humidity here is about 10%....suffice it to say my autofill runs A LOT at night
    I wake up early in the AM and open the blinds just to make sure all the water hasn't evaporated away...
    Matt
    May 2016
    Troy IL
    476
    I just got me a blue solar cover today and threw it on as the sun went down. Should I be taking it off during the day, or only when we want to swim? My primary concern is heating the water, not reducing evaporation. Though that'll be nice too.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    May 2015
    13,226
    Quote Originally Posted by camueller View Post
    If you need to heat the water then just leave it on until you swim and make sure it goes back on before the sun goes down. If no one uses the pool, then just plan to pull it off for a couple of hours each week during the day to let the water get some UV and outgas any CCs that might be hanging around.
    Matt
