Results 1 to 10 of 10
Thread: I Think I Have A Leak
    May 2016
    Toledo, OH
    81
    I think this is the right sub-forum for this.... I am testing my water level
    Currently doing the bucket test with the pump on and the water seems to be dropping on the pool side. Also my psi seems a bit low at 9. It was in the 12 range a few days ago. Turned off the pump and put some dye in around the light and skimmer box. They didn't seem to get sucked in. Need to try the drain still somehow.
    This pool will be the death of me this year. Already replaced all the pad equipment to start the season.
    My return and suction lines are under concrete.
    15,500 Gallon - In-Ground - Gunite Pool - Kidney Shape / Hayward S220T Sand Filter / 3/4 HP Hayward Pump / K-2006 Test Kit / Chlorine 3" Pucks
    Jun 2014
    15,103
    Re: I Think I Have A Leak
    Certainly hope you don't have a leak, but if you need more help let us know. Pool School - Leak Detection
    May 2016
    Toledo, OH
    81
    Thanks. I'm almost certain it's a leak. I remember when we got the house and had the pool company out they fixed a leak in the main drain area.....with that the pump only pulls water through the skimmer
    Jun 2014
    15,103
    If you haven't done so already ... it's best to try and isolate the leak to either the suction or pressure side. Water leaking with pump on would be the pressure side (and/or inside the shell). Shut the system down and find leaking then it's probably the suction side (or the pool shell somewhere as well). Close certain plumbing runs to try and isolate a location as well. Probably things you already know, just talking out loud.
    May 2016
    Toledo, OH
    81
    Quote Originally Posted by Texas Splash View Post
    Pump is running right now and water is lowering. I'm going to turn it off over night to see how it will progress. My bet right now is the drain...but I've never been good at gambling.
    May 2016
    Toledo, OH
    81
    Well the bad news is that it's still leaking with the pump off. But I guess the good news from that is that the leak is most likely inside the pool now.
    Jun 2014
    15,103
    Leaking continuously would point to something like behind your light in the niche, or around the seal of your skimmer/main drain. If you can't pinpoint it with water coloring of some sort, some people will simply let it drain for a while and see where it stops (i.e. at the light) then they have a good idea where the culprit it.
    30,419
    How much is it leaking?
    May 2016
    Toledo, OH
    81
    I'd say I lost about 1/2 inch overnight
    May 2016
    Toledo, OH
    81
    I think I may have found the leak. The water level held pretty consistent between the bucket and pool last night with the pump off. When we got the house a 4 or 5 years ago I remember the pool company saying that their was a leak with the main drain. Last night I replaced the rubber stopper that is in the drain line to the skimmer box and the water seemed to stay level. I am letting it go for another 8 hours today just to make sure. I also think I found the source of my high CC level last night when I pulled out the basket from the main drain. Lot of muck and leaves hiding in there.
