Results 1 to 15 of 15
Thread: Considering Pebble Tec but have concerns
    Sep 2015
    Atlantic Beach, FL
    70
    I've searched the archives, but didn't find any discussions of this particular question in the last year or so, and we're very close to nailing down our specs:
    Is Pebble Tec too rough?
    I understand the longevity advantages of Pebble Tec, but have read enough stories about how it's too rough on skin. That's a big concern.
    I also have read that plaster can last quite a long time if the pool's chemistry is kept in proper balance. Appearance-wise, I would probably be fine with either finish.
    So, experienced pool people, has the original Pebble Tec product been improved in the last few years, as far as its smoothness?
    If you recommend a different Pebble Tec product (Fina or Sheen), does it cost a great deal more than the original?
    Thanks in advance!
    8K gal 13'Wx19'L IG kidney. 3.5' to 5'6" depth. Pentair: Ultratemp 120 heater/chiller; Intelliflo 2 VS pump; Intellichlor IC40 SWG; cartridge filter; EasyTouch controller. 3 wall returns, 1 skimmer, 1 cleaner line. Tremron Oak Run coping and pavers. Noble Tile Toscano waterline. Marbletite's Freestone pebble in St. Thomas. TF100 and K1766 test kits.
    Aug 2014
    Houston tx
    2,524
    Re: Considering Pebble Tec but have concerns
    Plaza, it really is just a personal preference and what you consider rough. If you are someone who always wears shoes, then you may find it all too rough.
    PT comes in Tec, Sheen, Fina, Beadcrete and now Brillance (a mix of glass and pebble) with different size pebbles in each. Fina is supposed to be the smoothest pebble with the smallest pebbles. I have Sheen and don't think it's too rough although on occasion I have scraped the bottom of my toe. Tec has the larger Pebbles and I would figure it would be roughest. Beadcrete is all glass so I'm guessing would be super smooth.
    The best way to judge is to go visit pools with each of the finishes. Sorry I couldn't be much more help.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Jul 2015
    Central Valley CA
    1,108
    We have fina it's less expensive than the original large aggregate Pebble Tec and supposedly won't last quite as long 10 to 15 years avg vs 20+ from what we were told. As for the feel when walking laying or touching it I wold say not rough but not glass smooth either. No adults have complained or hurt themselves on and I spend hours at a time in the pool. One of the kids kicked the side while swimming it removed a few layers of skin of the top of a toe but I suspect that would have happened with any finish.
    I like Marlahoutex's suggestion though try to go feel a few.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    May 2016
    New Braunfels, TX
    30
    We're going through the same process and have ended up with PebbleSheen - White Diamonds, it's pretty smooth while still having visible pebbles. We considered Fina, but it looks like plain plaster to us.
    / 21k / IG / PebbleSheen / Jandy 60 sqft DE / Jandy VSSHP270aut (x2) / July 2016 / TF-100 / 400k Heater /
    Sep 2015
    Atlantic Beach, FL
    70
    Thanks for the replies.
    I'll ask our builder if he can direct us to some existing pools that we can check out.
    Our pool will be tiny, so no one will be playing volleyball in it for hours and no small kids here, so it's really just a concern about how rough it feels even without running around on it.
    These choices with long-term consequences are getting to me!
    May 2015
    Land O Lakes, FL
    527
    I went through the same thought process. I also had a local PB we were getting a quote from that had both Pebbletec and Pebblesheen in their display pools. We also tested out Pebblesheen on 2 other local pools.
    In the end we decided on Pebblesheen for a number of reasons.
    1. We loved the look of the pebbles and water color. We chose Blue Granite.
    2. It has a longer warranty
    3. It was not too rough. IMO, PebbleTec was too rough but not Pebblesheen. Now that we have had it for over a month, it actually seems like the perfect compromise. I have evaluated this in my mind heavily as I am playing with the kids, swimming, etc. and I have no reason to believe that we should have chosen something else.
    I have been in really smooth plaster pools and there is not enough grip. I have been in rough plaster pools and it can hurt your feel after a little while or even blister if in it a long time.
    Time will tell if it holds up but I never could find anything but the odd scenario where there might have been a install issue.
    One thing to know is that on the edges of the steps, it is rougher where there is a 90 degree angle. If you run into it hard, you may be scraped. This could happen when regular plaster too though but maybe not as often.
    Hope this helps. At this point, if I were to do it all over again, we would choose the same finish and color.
    On my build thread you can see pictures of the PebbleTec install in process and the final with water at the end. New Build Design, Equipment Plan Advice - Florida
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Sep 2015
    Atlantic Beach, FL
    70
    Thanks, Matt!
    What kind of price difference was there on the Pebblesheen?
    Apr 2009
    Northern Virgina
    55
    Agree with everything mgmoore7 said. I looked at Pebbletec and Pebblesheen and went with Pebblesheen. We have kids so comfort was definitely something we considered and Pebblesheen provides the right amount of traction without being too rough. It's a great looking finish but my main reason for going with Pebblesheen was the quality of the installers and the durability of the finish.
    22k gallon IG Anthony free-form pool and spa with PebbleSheen finish, Pentair WFDS-8 WhisperFlo Full Rated Dual-Speed 2HP pool pump, Sta-Rite S8D110 System 3 Grid D.E. 53 sq. ft. pool filter, Raypak R406A 399K BTU cupro-nickel propane heater, Polaris 280 pool cleaner with 3/4 HP PB4-60 booster pump, Goldline Aqua Plus controller and SWG, Inter-Fab G-Force pool slide.
    Mar 2016
    Las Vegas, NV
    39
    We had pebble fina on our last pool and are doing it again on this one. Yes, it looks a lot like regular plaster, but it has the aggregate crushed up in it and what you can't see from photos on the web is that some of the aggregate has quartz and stuff that sparkles in the sun. It's smooth and although you can get the occasional scrape, we've played basketball and volleyball for hours without trashing our feet.
    2016 build: 15'x30' rectangle in-ground pool, with 6'x6' spa. Depth 3'6"-5'0"-4'0" roughly 13,500 gallons. 8'x8' wet deck with led/bubbler. Intellibrite 5G pool and spa lights; SR Smith Typhoon Slide; Pentair VS pump and equipment; pebble fina grigio
    May 2015
    Land O Lakes, FL
    527
    Quote Originally Posted by Plazaglass View Post
    Thanks, Matt!
    Pebbletec and pebblesheen were the same price but tbere are upgraded colors within each that cost more.
    Matt
    Sep 2015
    Atlantic Beach, FL
    70
    Okay, I think I'm starting to feel better about Pebbletec products
    Jun 2015
    Orange County, CA
    145
    I have NPT mini-pebble, which is the equivalent of PebbleSheen. I've scraped my foot/toe and hand on it a couple times enough to draw blood. I wish it was a bit smoother. My neighbor has regular Pebbletec and it's definitely too rough for me. I've had kids get blisters and scrapes on our plaster. With all that being said, I would get the same finish cuz I love the look of my midnight blue and the durability. If money was no object, I would get the whole pool plastered with glass beads or tile.
    17k IG plaster pool+ spa, Stonescape mini-pebble midnight blue, marble coping, Trex and porcelain tile decking, Pentair Intelliflo VSP x 3 (filter, laminars and spa jets), Pentair IC40, Pentair MasterTemp 400, Pentair Quad DE 100, Pentair CC 150 for laminars, Intellibrite 5G LEDs, MagicStream Laminars x 3, Intellitouch i9+3 automation with Screenlogic2, IntellipH, Dolphin s300i, TFTest kit, SpeedStir
    May 2016
    New Braunfels, TX
    30
    We actually considered going with BeadCrete, but we heard that it can have issues as well. It was going to be substantially more expensive...buy pay once and enjoy, right? We heard: a) some of the beads break and can be sharp, b) it doesn't shimmer as much installed as it does on the little sample that the PB has.
    Sep 2015
    Atlantic Beach, FL
    70
    Well, we met with the PB today to start setting things into motion and it turns out he doesn't do Pebble Tec. I think I saw "pebble" in his rough estimate and my brain added "tec."
    So, he's speccing Premix Marbletite's Marquis or Freestone series. We now have the address of a local showroom we can visit. Don't know anything about this product yet, but I know I'll be looking for the smoothest finish they offer!
    Thanks, everyone, for your help. Apologize for the goose chase, but I'm sure this conversation will help others who search the site for Pebble Tec opinions.
    Jul 2015
    Central Valley CA
    1,108
    Pebble Tec is the main brand of quartz pool finish most everyone knows like Tempur Pedic is to memory foam So the exercise was not a total waist for the most part every manufacture has a product line that is comparable to the others both in texture and color palette offered.
