Thread: ph increaser not dissolving
    Jun 2014
    Central Maine
    21
    good evening,
    I mistakenly sprinkled 16oz of ph increaser onto the water instead of diluting it first. It's settling on the bottom of a vinyl liner newly installed.
    Brushing often today didn't help much. Will that damage the new liner in any way? Thanks, Jerry.
    12,500 gal. AG---extruded alum. with 1hp Hayward EC-50, D.E. filter ( both 30 yrs. old)--Taylor TF-100---well water
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: ph increaser not disolving
    pH increaser, which is likely just expensively packaged sodium carbonate, is less likely to cause damage to the liner than pH reducer or muriatic acid. I would still keep on brushing it often to help it dissolve.
    Next time you need to increase pH, buy some 20 Mule Team Borax in the laundry aisle. Much cheaper.
    Isolated Spa - 345 Gallons
    Jun 2014
    Central Maine
    21
    Right. But it's dark out and I cannot see the pool. Is first thing in the morning ok? or should I get the flashlight.
    Feb 2014
    Central Minnesota
    5,080
    Re: ph increaser not dissolving
    If you brushed it sometime this evening, I'd let it go. If not, find the headlamp! :P
    Jun 2014
    Central Maine
    21
    Ok, I'll brush it now and stay with it all day tomorrow. Thanks JVTrain
