Page 1 of 3 123 LastLast
Results 1 to 20 of 58
Thread: Pool still cloudy after a few weeks
    May 2009
    Glenwood, Maryland
    65
    Hello all, and thanks in advance for any help, especially Jason (Mod) who was helping me in another thread.
    My pool is still a light green and cloudy. This is my xx year opening my pool and this year seems to be the weirdest. Maybe its all the rain we have received.
    Here are my number from the last two days..
    Last night (7PM)
    CH - 5+
    pH - 7.0
    FC - 2
    CC - 1
    TC - 3
    CH - 275-300
    TA - 70
    CYA - 0 (Filled tube to top - Can still see dot)
    Added 5 gallons of bleach @ 12% strength. Misunderstood recommendation and Pool Math
    Last Night (9PM) - Tested 2 hours after adding 5 gallons of 12% strength bleach
    FC - 24
    CC - 2
    TC - 26
    CYA - 0
    Filled sock with CYA and left overnight.
    This morning (9AM) - Sock with CYA Stabilizer empty
    FC - 17
    CC - 2
    TC - 19
    CYA - 0
    Filled sock with CYA again.
    This Evening (5PM) - Sock with CYA 1/2 empty
    CH - 5+
    pH - 7.0
    FC - 4.5
    CC - 3.5
    TC - 8.0
    CYA - <20 but not 0 as I the water as the black dot is almost gone when tube is full. CYA sock is half empty from this am.
    As you can see, my numbers jumped around a bit from yesterday and today.
    Should I add more bleach to the pool?
    Pool Math states to add 2 gallons of 12% bleach, if I am reading correctly.
    Another question: Would a low CYA make the pool cloudy?
    Thanks everyone.
    Thanks, Golfer
    35K Gal Gunite Pool, Starite Cartridge Filter (S8M150), Lochinvar 400K BTU Propane Heater, Pentair 3HP Intellipro VS + SVRS Pump, Hayward 3HP Pump (Waterfall), Dolphin M-500 Pool Cleaner, Well Water, TFT-100 Test Kit w/ Speed Stir
    Jun 2014
    15,082
    Re: Pool still cloudy after a few weeks
    Your numbers did hop a bit, but mainly because you over-shot your FC and had no CYA to hold it. In any case, now that you have added stabilizer, go ahead and maintain an FC of "12" using regular bleach. Your pH is already set, so maintain the FC of 12 and "SLAM" (link below) until you pass the 3 criteria. Check the CYA in a day or two. If it's at 30, you're fine. If you went up to 40, increase FC to 16. If anything else seems odd, let us know. Good luck!
    May 2009
    Glenwood, Maryland
    65
    Thanks for the response.
    Here are my numbers at about 9PM EST
    After adding the bleach, a bit more than 2 gallons.
    The bleach may be a higher concentrate than I think.
    The company states its between 12% - 15%.
    But my FC jumped a small bit higher than what Pool Math said to add in order for me to reach an FC of 12.
    FC - 16.5
    CC - 2
    TC - 18.5
    CYA is now at 20. There is a little bit of stabilizer left in the sock.
    I kept the stabilizer sock in the pool.
    I guess we just let the pump and chemicals do their work now, correct?
    Test again in the am.
    Thx again.
    Thanks, Golfer
    Jun 2014
    15,082
    You're exactly right. The CYA should climb more overnight, and the FC will sink soon. So just maintain the FC of 12 and make sure to read the SLAM page each day as a reminder of things to do. The more vigilant you are with the FC level the better the SLAM will work in your favor. Have a good evening.
    May 2009
    Glenwood, Maryland
    65
    Here are my numbers from this am.
    I added no chemicals last night.
    Cartridge filters removed, cleaned and placed back into system last night.
    Stabilizer sock left in pool last night.
    FC - 22 (higher than last night)
    CC - 0 (Lower than last night)
    TC - 22 (higher than last night)
    CYA - <30 (a bit more cloudier, but can still see the black dot when full)
    Pool is still the same cloudiness as it has been for the last two weeks.
    Am I on the right track?
    Thx all...
    Thanks, Golfer
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    You are on the right track. The FC test is sensitive in that if you leave the solution sitting around too long, it will turn pink. Having the speedstir helps with accuracy since you don't have to drop and swirl. So, don't take too long and don't let the solution sit around.
    You don't need to test CYA as often as your are testing. It does take a day or two for the CYA to register on the test, but testing every time you test FC is overkill.
    If you keep overshooting your FC, it could be a combination that your your bleach is higher strength than the listed amount or your pool is smaller than you think.
    Keep on keeping on, testing FC and adding bleach as often as you can. Brush at least once a day, run pump 24 hours, clean cartridges when your pressure rises 25% above your clean pressure.
    Taking a photo of the pool each day will help you realize that you are making progress.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Jun 2014
    15,082
    Yes - definitely "maintain", and once that FC comes back down to 12, just keep it there. Keep brushing when you can each day to stir things up and expose the algae so the bleach can penetrate and do its job. You're on the right track.
    May 2009
    Glenwood, Maryland
    65
    Thanks for the response. I do have the speed stir and it does help.
    I test almost every area just to sure and to compare results. It may be a bit overkill, but I dont know. I go by what is recommended here.
    I have been opening and closing my pool for years and this is the first time that it has taken so long to become clear with little or no visual improvements.
    In the past when I had to SLAM, I could see improvements daily. Then one day I wake up and the pool is crystal clear.
    I just dont understand the cloudiness issue. Maybe algae is still present but the water was clear when I took the cover off a month or so ago.
    At that time I figured I was ahead of the game (from previous years) and didnt go full steam into a full open. Then one morning I woke up to the swamp, several weeks ago. (Live and learn).
    I put so much chlorine in the pool, I think to myself that I am on the wrong track. But I come in here and all of you tell me I am on the right track.
    Frustration holds no bounds at times with a swimming pool.
    The family wants me to drain it and get new water. At least it will be clean water and then go from there with the chemicals. But every day, I tell them we are closer. But the pool remains cloudy. Just a little venting...
    Thx again for the response..
    Thx Splash... As my post states above, it does get frustrating at times.. It never took this much time in the past.
    Thx again...
    Thanks, Golfer
    Jun 2014
    15,082
    Patience is a virtue in this scenario. No doubt that chlorine is the cure-all for algae. The trick is that FC/CYA ratio. CYA should clearly be 30 by tomorrow. If not, I would add a little more (10 ppm) to ensure your FC is receiving the top-cover it needs from the sun. The FC of 12 will work. You're cleaning the filters, so that's perfect. Also, at some point you'll probably want to pull the light out and check behind in its niche. That's a very common home for algae if you have one. Portable stairs or ladders are another.
    Make sure to take a pic each day near your steps/ladder so you can compare progress each day. Post here if you like so we can see as well. Have a nice day.
    May 2009
    Glenwood, Maryland
    65
    Here are a couple pics of my pool.
    Thanks, Golfer
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    Yep, that is a lot of green algae. You are are on track.
    FYI, on your note that the water didn't look too bad at opening. Algae needs light to reproduce, so the cover was keeping the algae from exploding. Once the light hit the water without the high enough FC, you loose the battle pretty quick. My pool water didn't look too bad at opening, but there was a lot of fine debris that settled on the bottom. The sediment turns the water cloudy after turning on the pump, brushing and vacuuming.
    This winter/spring was a hot mess for pools in the mid-Atlantic. The warm winter and freezing spring, it was difficult to open early because of the late hard freezes. To keep this from happening again, you want to close your pool late (water below 60) and open early (before water reaches 60 degrees).
    You are are track, just make sure you brush and vacuum daily.
    Karen
    May 2009
    Glenwood, Maryland
    65
    Here are my pm numbers..
    FC - 14
    CC - 0
    TC - 14
    CYA - It is now officially 20..
    According to the CYA chart, my FC is good.
    So no chemicals needed at this time.
    I will check again this evening and go from there.
    Thx KC and Splash for the responses...
    Thanks, Golfer
    May 2009
    Glenwood, Maryland
    65
    Here are my results for 8 PM...
    FC - 12
    CC - 1
    TC - 13
    CYA - 25
    CYA chart states that my FC should be at 12 for 30 CYA.
    So I am there..
    No chemicals needed tonight..
    Why would my CC go up?
    Thx
    Thanks, Golfer
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    CC can go up especially on cloudy days or at night. Uv light from the sun usually removes the ccs pretty efficiently. The other thing that removes ccs is more fc. Not a biggie.
    Karen
    Jun 2014
    15,082
    CC will fluctuate for various reasons, most applicable to the rate of FC consumption, amount of sunlight, and how quickly it (CC) can be oxidized. It's expected in a SLAM and you're doing good with those numbers.
    May 2009
    Glenwood, Maryland
    65
    Thanks Splash and KC...
    Quick question..
    During the SLAM effort, you need to keep the FC is step with the CYA.
    I read that you do not want to drop your FC below the guidelines.
    So in my case above, my FC level is just about on the money. CYA of about 30 = FC of 12.
    Since I am on the number, would it be wise to throw a bit more bleach in the pool to ensure the FC does not drop below the chart level (in this case 12)?
    Is it better to be a bit higher in FC than lower?
    Thx for all the responses.
    Thanks, Golfer
    Jun 2014
    15,082
    We've determined that it really doesn't help. Too high over a SLAM increases the potential for FC to simply burn faster, not really impacting the algae. Once we start saying, "Go a little higher", then the line between slightly high and too high becomes blurred. So we've agreed that everyone should just aim for their published SLAM level. For those that work all day and know it will drop a little, that's okay. They just increase back to the SLAM level when they get back. This also helps when some people inadvertently "over-dose" their pool (i.e. shooting for a target of 15 (3 above their SLAM) and accidentally going to 20). It happens.
    May 2009
    Glenwood, Maryland
    65
    Thx Splash,, Adding too much happened to me earlier this week or last...
    I got the numbers under better control right now.
    I will do the numbers again in the am and go from there.
    Thx again...
    Thanks, Golfer
    May 2009
    Glenwood, Maryland
    65
    Here are my results from today with a couple pictures.
    6AM Test
    FC - 13.5
    CC - .5
    TC - 14
    CYA - 29
    12PM Test
    FC - 14
    CC - 0
    TC - 14
    Thanks, Golfer
  20. Back To Top    #20
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Looking better!
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
