Thread: New pump
    May 2014
    Mount Airy, MD
    11
    New pump
    We need to buy a new pump. Our current pump is a Jacuzzi Magnum Force with an AO smith motor, 1 hp.
    I notice the Jacuzzi Magnum Force is still available. It would be nice to get that since then we won't have to change any piping, etc.
    But is there a better choice? Where we wouldn't have to adjust too much piping?
    Thanks
    Dayna
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: New pump
    If you can get one with 2 speeds, that might be a nice upgrade without changing fittings. Jacuzzi Bros. Jacuzzi Magnum Force Dual Speed 1 HP - 94027210 - INYOPools.com
    Running at low speed even for twice as long will save you $$ on electricity.
    Hard to tell if your pump is over or undersized without more details about your pool. Please add the details of your pool to your signature. Edit Signature
    Isolated Spa - 345 Gallons
    May 2014
    Mount Airy, MD
    11
    Re: New pump
    I'll add them later, I have lot to do today. So why are Jacuzzi pumps still being sold? I thought Jacuzzi went out of business? We had to replace our Jacuzzi sand filter 2 years ago.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: New pump
    They don't seem to think so.
    Hot Tubs, Bathtubs: Jacuzzi
    Sure, add the info whenever you get a chance and we can review it later.
    May 2014
    Mount Airy, MD
    11
    Re: New pump
    Well I still haven't added my info. Really. I should have it memorize...but we ended up taking the pump apart, and fixing part of it, so we just got a new motor.
    So that should be good for a bit.
    Thanks anyway. I do have a question about bleach... I will post in another section.
    Dayna
