Results 1 to 15 of 15
Thread: New Pool!
    May 2016
    Leonardo, NJ
    11
    New Pool!
    Hi All! First time pool owners here so please be gentle. Pool went up today and is filling but the electrician won't be here to run electric until Friday. Is there anything I can / should do in the meantime to prevent algae from grabbing hold?
    15x30x54 AG Swim n Play Westminster II
    13,500 gal Vinyl Liner
    Blue Torrent 1 1/2 HP 2 SP, Blue Torrent 23" sand filter
    TF-100 test kit
    May 2015
    Land O Lakes, FL
    527
    Re: New Pool!
    Add chlorine based on pool math and brush a few times a day to help distribute.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    triptyx's Avatar
    Apr 2016
    1,438
    Re: New Pool!
    Yes. Get some bleach in there and stir it around with a brush! Leaf rake daily to get any debris you can out of the pool.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    30,432
    Re: New Pool!
    I don't think I would add it according to Pool math. I would rather see one large jug of Clorox put in the pool each evening until you get your pump running and you can report test results with your handy dandy TF-100 (the world's best test kit...really)
    Once the electrician gets done, circulate that pool water for about an hour.....then take your sample (about 1 foot deep) and report your test results.
    May 2016
    Leonardo, NJ
    11
    Re: New Pool!
    I really appreciate all the advice. I am sure I will be bugging you guys ALOT!
    TF-100 test kit
    May 2016
    Leonardo, NJ
    11
    Re: New Pool!
    TF-100 test kit
    May 2016
    Leonardo, NJ
    11
    Re: New Pool!
    As you can see I also got a lot of landscaping to do.
    TF-100 test kit
    triptyx's Avatar
    Apr 2016
    1,438
    Re: New Pool!
    Quote Originally Posted by Yellbean View Post
    Sent from my SM-N920T using Tapatalk
    Bug away! We love pool problems.
    There's a pool. Looks fine to me!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Re: New Pool!
    Right, ya'll don't like dirt up there?
    Welcome to TFP and congrats on the pool!
    May 2016
    Leonardo, NJ
    11
    Re: New Pool!
    FC 2
    CC 0
    Ph 7.2
    Cya wife just added 16 oz stablizer yesterday but tested anyway less than 20. Could see dot when filled.
    Ta 120
    So the pool is up and running. So after me throwing some bleach in daily and the wife adding 1 16oz dry stabilizer, about 8oz dry shock and a puck in a floating frog yesterday, here is where I'm at. Whatcha think?
    TF-100 test kit
    May 2016
    Leonardo, NJ
    11
    Re: New Pool!
    Just added 26oz of 12.5 chlorine as per pool calc. Still have Cya set to 0
    TF-100 test kit
    May 2016
    Leonardo, NJ
    11
    Re: New Pool!
    How long until I will get a reliable reading of Cya? My wife added the stabilizer while I was out and I didn't tell her I was trying to follow the TFP method so she figured it was in the start up kit so it should go in. I don't think it should be a problem as I am starting from 0 Cya and I think I will need to add more to make 30ppm. So my question is do I aim for a free chlorine level of 0 or of 30 which is my goal?
    TF-100 test kit
    DFW, TX
    24,517
    Re: New Pool!
    If it was granular and added as we advise here, Pool School - Recommended Pool Chemicals, then it will show up on the test 24 hours after it is fully dissolved from the sock.
    If it was poured into the skimmer and is now in the filter then it will take a week or so to show up on the test. Do not backwash the filter until it reads on the test or you could lose the CYA.
    To be safe you should chlorinate based on the 30ppm that was added to the pool.
    May 2016
    Leonardo, NJ
    11
    Re: New Pool!
    It was added to the skimmer. So I chlorinate as if 30ppm. Thank you
    TF-100 test kit
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,288
    Re: New Pool!
    Welcome to TFP. Good to have you hear, and congrats on the new pool! Sounds like you're off to a good start with around 3 PPM FC to match your CYA at 30 PPM.
    Trouble Free Pool Care (TFPC) includes always knowing what each addition of pool chems is going to add to the water and what effect it's going to have.
    When it comes to TFPC pool chem advice, you won't hear "try this, it should work" like you do at a pool $tore.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
