Thread: TA high but PH high
    hauntedmansion138's Avatar
    Jun 2016
    Weyers Cave, VA
    35
    TA high but PH high
    So my PH is good at 7.5 but TA is high around 220 (hope it's right as I have bad tips on my bottle)
    Pool Math is not showing to do anything. Should I add acid or leave as is?
    16x32 52" AG oval Century pool (14400 gallons we think). Vinyl liner. Hayward Pro Series sand filter S166T model. Hayward Power-Flo Marrix SP151021XEHC 1HP pump. Had the pool since 5/27/16. TFT-100 test kit. Water delivery initially, but use well water to top off when needed.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: TA high but PH high
    Quote Originally Posted by hauntedmansion138 View Post
    Leave it alone. pH will come up in a few days and when it hits 7.8 or higher, lower it again and TA will automatically go down a little bit.
    Jun 2016
    Weyers Cave, VA
    35
    Excellent! I love this aeration thing. It's cheap and easy
