Results 1 to 14 of 14
Thread: Anyone have these wedding cake steps?
    TomGallopavo's Avatar
    Apr 2016
    Hillbillyville, MO
    161
    Wedding Cake Steps...do you like them?
    Spring 2016 Install, 24'x54" Saltwater LX AG Round Pool (13500 gal.), AquaPro 200 SQ. FT. Cartridge Filter System 2-HP 2-Speed Pump, Solaxx Saltron Retro Jet RJ Saltwater Chlorine Generator, Aqualuminator Above Ground Pool Light, TF-100 Test Kit w/ Borate and Salt, Well Water.
    Jun 2014
    15,189
    Re: Anyone have these wedding cake steps?
    Hi Tom. We'll try to give this some more visibility. Good luck.
    bluegirl2's Avatar
    Jun 2014
    Southern WI
    24
    Hi Tom and everyone else! First time posting on the forum. In my opinion, I had them and hated them! It was too hard to clean underneath the wedding cake steps because algae, dirt and sand would accumulate under them. I bought a Confer A-Frame ladder which works only for a rigid-framed pool and I like it. I hope this helps! ��
    2010 Build- AG Diamond Star Vinyl - 17,700 gal - 18'X33' - 4.5" Deep - Hayward EC50C93S Extended-Cycle DE Filter w/new Powerflo Matrix Pump - 1.5 Horsepower -Taylor K-2006 Complete (FAS-DPD chlorine) Test Kit. Southern WI
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    574
    I can say that they are stable and hold larger people very well. They really make it possible for my disabled mother in law to be able to get in.
    The thing that I absolutely hate about them is the insane amount if weight needed to to hold them in place. It is absurd. And with all that weight it makes it extremely hard to clean under as it's difficult to move them.
    Everything wants to collect under them and it's just an all around nightmare.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Casey's Avatar
    SW PA
    10,450
    I had something like this several years ago. I loved them because my kids and their friends could play on them. They were horrible when it came to cleaning because the water could not flow freely and it bred algae like crazy.
    mbuice's Avatar
    Jul 2014
    Denton, TX
    95
    I agree with Casey. I have something similar, but from what I've read and experienced, any wedding cake steps are going to require some extra work to keep the algae away. I've found that if I just add a little of my chlorine directly over the steps and use the brush to swish the water around it seems to work well.
    18 X 34 AGP 7ft deep end, 22,300 gallons. 250lb sand filter, 2 speed 1.5 hp pump. TF-100 Test Kit.
    Jul 2013
    Southwestern Indiana
    11
    I have them, and do not like them. As others mentioned, they are difficult to clean around, tend to grow algae, and require about 150lbs of sand or some other weight to keep them down. Two years ago, one of my sand bags broke in the middle of the season, causing sand to spread across the bottom of the pool. Last year, I tried using bags of river rock instead of sand, which seemed to work a little better, but were still a pain to put in and clean.
    24x4 round AG Doughboy, 13.5K gallons, installed 2007
    Multiport Sand filter, Hayward Power Flo LX pump, HP: 1.5, SPL: 70 GPM
    Manual vacuum, nylon brush, Auqaluminator light, wedding cake stairs
    I guess I'll pile on with Casey and bluegirl.
    Algae bed. Hard to hold down.
    AG | 18x33 Oval | vinyl | 15k gallons | 1.5 hp sand filter | multi port | installed summer 2013
    Apr 2016
    Kankakee Il
    39
    I have them, love them from a function standpoint. They do take a serious amount of weight to hold down through. I have a total of 10' of 4" PVC pipe filled with sand attached to them and they still want to walk a little.
    24' saltwater 8000 installed halfway in the ground, Hayward perflex ec40 hardpiped, Saltron retro xl swg, aqualuminator return jet light
    kk_isme's Avatar
    Aug 2015
    North Central Texas
    108
    I was looking at getting these, but I went with the confer step 1 instead. It has freer water flow underneath, so algae isn't such a problem. They also attach to the deck, so not much wiggle going on. I had thought I might upgrade to the wedding cake steps in a few years. Not sure now, after reading these comments.
    14,000 gallon above ground 24ftx56in round vinyl overlap liner steel wall sand filter 1/2 hp pump heavy lime in city water morning shade
    NewPoolOwner2014's Avatar
    Apr 2014
    Pearland, Texas
    38
    I have both confer and wedding cake steps. With young kids the steps are great. I do take special care to sweep and bleach around them to keep algae away.
    16x32 AG Oval-54", 15k gallons, Cornelius Monterrey Resin
    Hayward S series sand filter, Hayward powerflo LX series 1-1/2 HP pump, hard PVC plumbed with 2 floor drains, 2 jets and wide mouth skimmer, TF-100 test kit
    My pool build thread: http://www.troublefreepool.com/threa...120#post642120
    Casey's Avatar
    SW PA
    10,450
    Quote Originally Posted by NewPoolOwner2014 View Post
    They are so nice for kids. As long as you take thel time to clean behind them, they serve a valuable purpose. My kids loved them. They always parked on the steps.
    Jul 2015
    Port Neches, TX
    53
    I have these that we are about to install I think they are Lumio wedding cake II
    We drilled extra wide holes in various places to aid with water flow. We made weights out of large pvc pipes filled with sand and water and sealed.
    Our only dilemma now is how to keep the top step (ballast) full of pea gravel and water without having the water squish out from the rubber plug when you step on it!!
    We filled it and assembled it but when we stepped on it air bubbles came out. That means that once the gravel grows algae, and I'm assuming it will, that it will shoot algae water into the pool when you use the steps.
    Does anyone know of a way to permanently seal the rubber plug to make it water tight??? Or if periodically adding bleach into the ballast will dissolve the rubber plug?? Leaving them out until we figure it out
    22' x 52" Intex UltraFrame ABG, 10,500 gallons
    using TF-100 test kit
    Krystal Klear 633T Filter Type B pump - 2,500 GPH
    Intex wall-mount surface skimmer
    Apr 2016
    Hillbillyville, MO
    161
    Thank you for sharing your experiences, we have decided to look for something else.
