Thread: Why does my Dolphin float?
    poolhound's Avatar
    May 2008
    Elgin, SC
    54
    When I leave my M400 in the pool it is on the bottom and when I come out the next morning it's floating. I get in and turn it several ways, sideways and upside down, til no more bubbles come out and it sinks to the bottom. Next day it's floating again. Anyone had the same experience and has discovered where the air is coming from? This doesn't present any problem, if I turn it on while it's floating it sinks and goes right to work.
    PS: Love my Dolphin
    24000gal IG, VL, 1.5 HP, Pentair 60/60D Sand 325#, BBB, Stenner45MHP2 (Replaced Liquidator), Dolphin M400
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Why does my Dolphin float?
    It is probably climbing out of the pool and captures air. There should be an adjustment to prevent it from climbing out of the pool.
    Mark
    poolhound's Avatar
    May 2008
    Elgin, SC
    54
    It is turned off, not plugged in to anything. The power supply is in my shed.
    38,235
    You have to purge the air. On my older one, you would have to put it in the water upside down and move it around so all the air would come out.
    poolhound's Avatar
    May 2008
    Elgin, SC
    54
    Done that. See first post.
    38,235
    Oops, need to read more
    Well the air ain't reappearing
    Do you have floats on the handle you can remove?
