Thread: To deep clean my sand filter
    Feb 2015
    North Alabama
    58
    It's time for a deep clean. I've never done this before.
    I read the sticky about deep cleaning a sand filter, but unsure which part I have to disassemble. Do the pipes have to come off? Or if I just unscrew the 6 bolts holding the multiport, will that reveal the sand?
    saltwater generator - Hayward turbo cell
    Whisperflo multiport valve sand filter
    25,000 gallon vinyl pool (20x40 rectangular)
    Polaris 280
    TF-100 test kit
    38,248
    Re: To deep clean my sand filter
    You are going to have to cut the 3 pipes (and add union fittings to them). Then the entire top comes off (not the 6 bolts).
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    In the case of that type of sand filter, top mounted MPV, you have to remove the pipes to get complete access to the filter. One great advantage that side mount MPV filters have... On the right side, you could disconnect from the SWG at that fitting by unscrewing from the looks of it. Are there threaded fittings you can disconnect on the other two lines? Other wise, you'll have to cut the pipes and when putting back together, install unions so you can easily do it again if necessary:
    Install a union on the SWG side as well so that you don't have a huge pipe hanging off the MPV would be best.
    Isolated Spa - 345 Gallons
