Thread: Adding Second Return
    Jul 2015
    Charter Oak, California
    273
    I'm having a bit of difficulty controlling algae in my pool and it has been suggested that poorly circulated water in my 12 x 24 Intex Ultra Frame Pool could be part of the problem. Currently running the stock 1/2 HP pump and 12" Sand Filter (Pump Rated @ 2100 flow rate/Actual Flow Rate 1600 gph)It has been suggested that a higher HP pump and larger sand filter may help. Also, a suggestion was made to add a second return. I've looked at a couple posts, but am unclear where to place the new return. The dead spot, as far as circulation is concerned, is to the left of the original return. The original return is just to the left of center on the 24' side of the pool about 12 inches below the waterline. (See Attached image)I assume the second return should go towards the dead spot on the same side of the pool as the current return is located. (Which would be to the left of the current return. See attached image) But, how far down should it go or is it not that important? Any suggestions?Hope this makes a little sense anyway...
    Bob (AKA Schnozz)
    12 x 24 x 52 Intex Ultra Frame AGP, 8600 Gal; Pentair 2HP/2SP 150sqft Cartridge Filter; Hayward Through Wall Skimmer; Intex Automatic Cleaner (Fantastic); K-2006 Test Kit; Start-up 07/30/2015. First Time Pool Owner in SoCal.
    Jun 2015
    Stockholm, Sweden
    250
    Re: Adding Second Return
    I did mine at the same height as the original one, thought it looked better. I dont think it makes much difference circulation wise. Just make sure you point both return jets to the left and down towards the bottom. Then you create a clockwise circulation around the pool.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    jmcdtucson's Avatar
    Jun 2014
    317
    If it were me, I'd do some other upgrades before adding a 2nd return.
    #1 a skimmer - that will keep your pool much cleaner, less algae
    #2 a bigger pump. That pump is really undersized for that pool.
    Not 100% sure, but I think you'd get more bang out of those upgrades.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Jul 2015
    273
    Thanks for the input...
    I have an over the wall Intex skimmer now. But you think a through the wall skimmer will work better and more efficiently and may increase flow?
    I'm currently running the stock 1/2 HP pump and 12" Sand filter (2100 Flow Rated Pump/ Actually 1600 GPH). Do you think an upgrade to a 3/4 HP pump and larger sand filter would be enough, or should I go all the way to a 1 HP pump and larger still sand filter? Do you believe a larger pump and sand filter will help with water circulation and dead spots I may have?
    Oh, I just read your signature, you have the same size Ultra Frame as we have with a larger pump, I think 3/4 HP? And you have a through the wall skimmer as well?
    Bob (AKA Schnozz)
    jmcdtucson's Avatar
    Jun 2014
    317
    I'm not sure the HP, but that's probably right. It's sold as a 3,000 GPH but system only pushes 2450? It's a big step up from the one you have which I thought was a tad underpowered for this pool. I really don't see any need for a 1HP pump for this pool but it wouldn't hurt.
    I had the Intex skimmer at first and it was very unreliable and would pop off the side and make my pump suck air, etc. I hated it. The best upgrade I've done is the thru-wall skimmer. It cleans the pool much better and is 100% reliable.
    But then again if the Intex works for you (it does seem to work for some people) then there's no reason to change.
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
