Thread: Incorrect back washing lead to sand
    Jun 2016
    Enon Ohio
    5
    Got pointed 18x42 pool all set up and went to use new intex sand filter pump this morning. Started off with backwash as instructed then moved on to rinse then to filter. Noticed that there wasn't much water movement in pool and no suction. Hubby realized he'd connected one of the hoses of the pump to the drain instead of in. Fixed it and suddenly we thought we were good until we noticed the pile of sand on bottom of pool. Could this be result of backwashing with incorrect hook up? Pump is brand new so I'm doubting it has to do with anything being cracked. I didn't notice any more additional sand to the pile despite running the pump on filter for about 4 hours.
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    333
    Re: Incorrect back washing lead to sand
    When backwashing did water go into the pool or out onto the grass. If not on grass then you could have sent loose sand into the pool.
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
    Jun 2016
    Enon Ohio
    5
    Quote Originally Posted by JoeSelf View Post
    Some definitely came out the in hole but it never stopped coming out. I never checked to see if water was going into the pool though. I only thought that could be the case when I saw all the sand sitting right under the one port.
