Thread: Question about adding Second suction to Pool from Original suction drain.
    Jan 2014
    Southern California
    58
    Hi guys have a question. I am currently remodeling my pool. My pool has only one suction drain at the bottom of the pool but my spa has two. A contractor recommended me to add another suction drain to my pool tapped into the same line of my original suction drain (basically break my gunite and run another suction drain tied into the original). Does this make sense to do? I could understand running a whole new line from the equipment and adding a suction drain but not to sure about just adding another to the same line. Anybody have any advice if this will help my pool or is this contractor b/s me?
    Thank you
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Re: Question about adding Second suction to Pool from Original suction drain.
    That is to be compliant with the Virgina Graeme Baker law. Adding a separate individual line would not serve that purpose as you could still get sucked down to it. Having two drains a certain distance apart plumbed to the same line allows there not to be an entrapment risk.
    http://www.cpsc.gov/PageFiles/105477/vgb.pdf
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jan 2015
    las vegas
    92
    Ask about installing a channel drain instead, meets current code and normally can be connected to existing suction line.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Here's an example of what LVP is referring to...
    It's a good option.
    http://www.aamfg.com/avscDrain.php
