Results 1 to 9 of 9
Thread: Brand New SWG Pool...What to do with testing???
    teat461's Avatar
    Jan 2016
    Newton,NC
    7
    We just got our pool installed last week. We went to local pool supply for water testing and bought what chemicals were recommended. But now I want to learn to do my own testing.
    WHERE do I start? What test kit is recommended? Any help would be appreciated.
    Teat461
    14 x 31 fiberglass pool , 12,500 gal, SWG, Jandy Pro Truclear 3/4 hp pump, sand filter
    Aug 2013
    Oklahoma City, OK
    139
    Re: Brand New SWG Pool...What to do with testing???
    I would start by returning everything that the pool store sold you. The only thing you would really need to keep (which i buy at lowe's or home depot) is acid to lower PH and maybe some CYA. Enjoy!
    20000 Gallon, Sand Filter, IG Plaster, Hayward Aqua Rite 40k SWG, TF-100 Test Kit, Taylor SpeedStir
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Welcome! Test Kit Comparison here for your reading: Pool School - Test Kits Compared
    Here is the most recommended test kit: TFTestkits.net
    The K-2006 is also a good kit, but the TF-100 comes with more reagents and is a better value. TFT also sells K-1766 Taylor Salt Test (drop test) or Salt Test Strips - Aqua Chek to verify your salt levels. Once you get a kit, folks will assist along with the links in Pool School to get you up to speed.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    teat461's Avatar
    Jan 2016
    Newton,NC
    7
    Thanks for the quick replies. What can I buy besides the pool supply chemicals? Someone told me to buy baking soda at Sams club and muriatic acid at Lowes.
    Teat461
    themadangler's Avatar
    May 2016
    Southampton, NJ
    127
    I'm new here but I think you should get a good test kit first, test your water, post the results and someone will give you guidance on what to do next.
    Diamond Pool 20'x40' Lazy L, approx 33,000 gal vinyl liner, Hayward s244T filter, Pentair Intellichlor Ic 40( new May 2016) replaced computer pool cpsc35, inter mastic T40404R, A.O.Smith UST1152 super pump 1.5 hp, Hayward heater, not working or by-passed, Polaris 360
    teat461's Avatar
    Jan 2016
    Newton,NC
    7
    Thanks for the quick reply. Do I buy muriatic acid and if so what does it take the place of? Someone also told me to use baking soda (bulk from Sams Club).
    Thanks for the quick reply. Do I also need to buy salt test strips with this kit? That is the one I was leaning toward because of recommendations on this site.
    Teat461
    May 2016
    Southampton, NJ
    127
    Quote Originally Posted by teat461 View Post
    If you have the test kit, the first step would be to test all the parameters of your water and post your results so advice can be given. Yes to a kit that will test salt since you have a swg. I use the Taylor k1766 not strips
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,476
    Here ya go:
    BUT I really want you to read this a few times. It is a LOT of info. so take it tiny bites at a time:
    When you get your test kit and start using what you have read it will really all start coming together.
    Kim
    30,419
    You can't determine what your pool needs until you perform effective tests to find out what it already has.
