Results 1 to 8 of 8
Thread: Channel around pool steps? What is this thing?
    threecheese's Avatar
    Jun 2014
    Long Island, NY
    56
    There is a channel around my pool steps, I am not sure what it's purpose is and I cannot find anything on the web. It looks like some type of channel/female that accepts a male .. something.
    Please excuse the algae, those stairs are a PITA! :P
    Thanks!
    30kgal in-ground/steel with vinyl liner, aluminum bullnose coping || 1 H.P. superpump || Polaris P9550 robot|| Hayward 48sq ft DE filter || Taylor K2006 kit
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Channel around pool steps? What is this thing?
    That's a standard track for keeping the liner in place around steps. Usually there is a T shaped piece of moulding that covers the track to cover the screw heads and give it a finished look.
    Isolated Spa - 345 Gallons
    May 2014
    Macungie, Pennsylvania
    23
    I have the same thing around my steps. I would be interested if anyone knows where to get the cover moulding that goes onto the track (part that covers the screws. I have a broken piece and would like to replace it. I have not been able to find it anywhere.
    15k Gal, Mt. Lake, Vinyl IG Pool.
    Built 2013/2014. 1.5 HP Jandy Pump
    Jandy SFTM25 Sand Filter.
    Taylor TF-100 kit
    Aug 2014
    Albany ny
    65
    Google fox pools stair parts, looks like those might be the same style.
    Kris
    14x26 rectangle vinyl liner pool . 1.5 hp 2 speed tri star pump, 2 aqua genie skimmers , no main drain. 175 sq ft star clear cartridge filter. 200,000 btu hayward heater Tf-100
    May 2014
    23
    Thanks!
    Taylor TF-100 kit
    Her pool boy's Avatar
    May 2016
    St Catharines, Ontario, Canada
    88
    I have the same stairs, and track. Same bare screws. Wonder if the insert was just poorly made, and did last long as it would appear this is a chronic condition. I just had my liner replaces and that is the seal for the strairs that keeps the water in the pool. Let me know if you find a place that sells the replacement. I would love to finish my new liner off by trim up the stair frame.
    Just saw the post above, and found also...thanks
    SteveS
    16' x 50' - 95K L (25000 gallon) I.G. Vinyl liner 12.5 Liquid Chlorine
    Wicor Pantera P24 Sand Filter Pentair Superflo Variable Speed Pump
    Zodiac 3510WD Robotic Cleaner Raypak R336A Heater. ​Taylor K2006c test kit
    Jun 2014
    Long Island, NY
    56
    Thanks! I didn't realize this keeps the liner on, I have a leak and suspect it is in this area, I will pay close attention to this thing.
    Aug 2014
    Albany ny
    65
    Quote Originally Posted by threecheese View Post
    The piece in question is purely aesthetic... To cover screws.
    Kris
