Thread: How to measure your pool - Lagoona
    May 2015
    Toronto
    183
    Hi,
    Any tips on how to find the volume of water for a Lagoona style pool?
    Jun 2016
    Leander, Texas
    101
    Re: How to measure your pool - Lagoona
    I'm new, so I'm not sure, but I believe you average the depth, use length and width and set the calculator to rectangle.
    16,600 gallon, freeform, gunite and plaster pool/spa combo. Hayward SP3207EE pump, S310T sand filter, Century 1081 boost pump and Aqualogic panel.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    I would start by using the oval calculation in the Pool Calculator and adjusting from there based on FC dosing and testing.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    May 2015
    Toronto
    183
    Thank you
    23K gal (I think), IG vinyl lagoona, Sta-Rite Hi-Rate Sand Filter T-240BP-1, Pentair Superflo VS 1.5 Pump (342001), June 2007, Taylor K-2006, Hayward Chlorine Feeder CL220, Water source from garden hose w/ water restrictions | 1HP Sta-Rite DYNA-GLAS MPRA6E-147L single speed pump
